20 Most Recent
Samsung ST600 Digital Camera Questions & Answers
Cannot be power on
remove the battery and try to charge the battery, before you put it back in. If you have a multimeter, try to measure the voltage of the battery. It should be just a few tenths of a volt higher than what is printed on the battery. Before reinserting the battery, check the contacts of both the battery and in the camera. They should be clean and shiny. Only to be cleaned with a dry cloth is needed. Then reinsert the battery and try switching it on again.
If it still does not work, you should visit a service centre or repair shop. But I think (most of the time it is) the battery is the culprit.
I have st6000 digital camera. when i goto change some settings some options cannot be selected sometimes.(like touch screen not working properly). so how do i reset my camera to factory settings.?
First you have to be sure, you could select the same options in the same menu, with the same settings before.
Most of the time when you can't select a certain option, it has to do with the chosen setting. So if you are in automatic, you can't change white balance or the ISO and lots of other things. Also when you are in a scene mode, lots of things can't be changed or chosen.
Most camera's don't have any way to go back to the factory settings. You can set back some settings you made, but most of the time, things like language, date time and some other things will stay as you put them in. Don't think your "computer" in the camera does not function correct, unless the camera gives some warning on the screen, or Samsung comes with an update of the firmware.
Blurred photos
You should check to ensure the camera is set on Auto Focus. Might be a switch on the body.
St600
This sounds like system is down and need service / repairs
Displaying demo mode problem
Remove the memory card, and the battery ,wait 10 sec and install them back ..next go to the settings menu ...in shooting or playback mode, select MENU ,Select Settings , and then RESET >>YES ..save settings.
Hi
I have samsung ST600 digital
You need to refer to the documentation for whatever program you're using to print your pictures. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens.
How old is the battery and do you use the camera a lot?
Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter.
I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot.
If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
