20 Most Recent KLH KD1220 DVD Player Questions & Answers
time for a replacement .
KLH KD1220 DVD... | Answered on Jan 05, 2018
i need a manual I need one sent to me
KLH KD1220 DVD... | Answered on Sep 29, 2013
how to hook this up to a recei
ver
KLH KD1220 DVD... | Answered on Nov 15, 2012
Hi dbm772,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can
KLH KD1220 DVD... | Answered on Mar 06, 2011
comcast , or wave broadband
remote is compatable
KLH KD1220 DVD... | Answered on Oct 11, 2010
If the cd´s play and the dvd´s don´t the only thing are the motor disc spindle looses velocity and can´t read the dvd
KLH KD1220 DVD... | Answered on Sep 10, 2010
Either the laser lens eye is dirty and needs to be cleaned with rubbing alcohol and a cotton swab.
Or you can open the door and blow inside real hard about 3 times.
If cleaning doesn't help, then the laser lens circuit is faulty and needs to be replaced.
KLH KD1220 DVD... | Answered on Apr 21, 2010
comcast remote, it works
KLH KD1220 DVD... | Answered on Mar 05, 2010
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
KLH KD1220 DVD... | Answered on Mar 03, 2010
...one of our sharp people found this about the KD1220:
http://www.fixya.com/support/t394781-klh_1220dvdplayer
...related issues:
http://www.fixya.com/support/t167279-dvd_player_good_resume_function
Videohelp had this stuff:
http://www.videohelp.com/dvdplayers/klh-kd-1220/2684
Ask KLH who would have the current info on your manual (email or
use this contact page):
http://www.klhaudio.com/faq.html
They may have discontinued that product line.
WW
KLH KD1220 DVD... | Answered on Oct 09, 2009
Hi and welcome to FixYa,
As antiochpc has initially proposed, clean the lens. This could be performed by using a cleaning disc. Should this be not corrective, then the top cover should be removed and the laser optics manually cleaned using cotton buds. it may also help spraying the mechanism with a can of compressed air to remove dirt and other debris.
Additionally, could be a mechanical problem. The carriage (where the laser optics ride) couldnot traverse its route. Most likely dried up lubricant on the sliderbar. This would be the small shafting thatguides the carriage of the laser pickup. Dirt, grime, dust andsolidified lubricant can cause stoppage of the carriage and the lasereye then fails to read the next track.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
KLH KD1220 DVD... | Answered on Jan 14, 2009
get a better dvd player. KLH SUCKS ****!
KLH KD1220 DVD Player Logo
28 questions posted
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • KLH Televison & Video
Most Popular Question
parental lock
  • Televison & Video
