20 Most Recent KLH DVD8350 DVD Player Questions & Answers
The player mechanism has failed.
KLH DVD8350 DVD... | Answered on Jul 23, 2017
720 is the usual output from a DVD. Usually if you futz with the settings long enough, you'll find where most TVs can at least fill the screen by re-sampling, and SOME DVD players will have settings that will do the re-sampling for you and output 1080i, again just to fill your screen. But don't be fooled... only Blue Ray disks will give you true 1080i resolution. .
KLH DVD8350 DVD... | Answered on Jun 02, 2017
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
all you need to do is match the cable type of the DVD to the TV and set the input on the TV to the same type be it HDMI or rca cables
KLH DVD8350 DVD... | Answered on Jan 30, 2016
What sort of tv do you have?
KLH DVD8350 DVD... | Answered on Mar 04, 2014
open up your remote then separate the rubber / key pads then clean the cercuit using home dry cleaner and leave to dry close your remote gently and its fresh again. reason for this is practice is because moist cause cover between pads and circuit board and thus no contact then no function
KLH DVD8350 DVD... | Answered on Jun 02, 2013
There are three coloured leads on the back of a DVD player if you use composite video - Red is Right channel sound, white is Left channel, yellow is video.
Red from DVD right output to TV right input
White from DVD left output to TV left input
Yellow from DVD video out to TV video in
KLH DVD8350 DVD... | Answered on Sep 03, 2012
plug it in hook the wires up hit the arrow button that will open it upput the disk in and it should work
KLH DVD8350 DVD... | Answered on Aug 24, 2012
The video processing circuits are not functioning fully and are blanking out part of the video. This is a highly intergrated area in the player and is not costwise to repair since you can get another player (used) for $20 to $25 with doing a google search. A new one is not available.
KLH DVD8350 DVD... | Answered on May 29, 2011
KLH DVD8350 DVD Player Logo
37 questions posted
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • KLH Televison & Video
Most Popular Question
illustration hookup cables klh dvd8350
  • Televison & Video
