20 Most Recent
KLH ASW12-120 Subwoofer Questions & Answers
How to connect to TV
Find the "Sub Out" connector on your TV. Likely an RCA jack. Run a cable from the TV to the Sub's Input and you're done. If your TV doesn't have a Sub Out then you might be out of luck.
I just aquired this unit from a friend who was
hi,
If possible check the crossover circuit board. There will be two or more ICs ( integrated circuits). fast of all just replace all the ics in that board. That ics will be very cheep in price. after replacing those ics make a test. if then also the cracking sound hears then you have to check the components amplifier board.
ok
I am looking for a replacement sub amplifier,
Or you could just write of the built-in amp, disconnect the sub from it and run the driver's leads outside the box, buy any decent amp, connect it to the LFE feed for inout and the bass driver for output and carry on.
That's what I did when a second copy of a powered sub died the same way the first one did.
Fuse keeps blowing out
Suspect an overload in either the power supply or main amp section. Chances are some kind of semi-conductor has gone gone short circuit. You might be able to spot it with either a crack or damage or signs of burning. If it is a transistor an Ohm Meter will show it up, as it will be just like you had touched the probes together, when touching two terminals with them.
