20 Most Recent KLH DVZ-2500 System Questions & Answers
2001 or 3308
KLH DVZ-2500... | Answered on Jul 26, 2015
Go back into the set up and factory set it then go back through the end user set up again. Sony bipass code is 7774 for parental control Not sure where that 1s made. That dont work track down the customer service number for the manufacture
KLH DVZ-2500... | Answered on Mar 23, 2015
Your problem is VERY common. It's defective, get a replacement.
"http://alatest.com/user-reviews/other-home-audio/klh-sequel-e-series-dvz-2500/pu3-38645822,106/?sid=230492&sort=-source-rating&limitstart=10
2.0 out of 5 stars Not bad for price $70+$30 S&H, October 20, 2003 By A Customer
This review is from: KLH DVZ-2500 DVD Home Theater System (Electronics) I read alot of the recent reviews before purchasing this system. I wasn't going to buy it because of the volume problem (too loud) but some people said that this could be lowered in the 'audio properties > dynamics' setting.
Sure enough, there is a setting, but it does NOT lower the volume level at all. So, I rang the toll free 888 number and this audio level problem is a defect. However, the dynamic setting is purely to make some sounds softer, not to lower volume. I was told to get a replacement. The replacement is the exact same way ... defective. Buy this system if you only want to hear _DVDs_ with all speakers, because there are no inputs. And the radio, CD is at best stereo,
AND
if you don't mind the fact that it will be too loud, if at any stage you want a normal listening level. I gave 2 stars because I was able to watch a DVD ok with volume level one.
KLH DVZ-2500... | Answered on Feb 26, 2011
when u turn da pc on, keep pressing f8 until a menu comes up den click safe mode and u should be able to reset ur admin password. I hope dis helped =)
KLH DVZ-2500... | Answered on Feb 13, 2010
3308
I am unsure how you get the proper bands and belts but i can help you with the electronic components. I use a website called Mouser.com. The components on the website are from many different dealers varying in quality and price. I really like the website because they show pictures of components and have a good search engine that allows you to get exactly what you need. Their prices are good, but shipping on a one dollar part can be 5 or so dollars. Because of this i make lists of components i need or know I'm going to need, and buy them all at once. This makes shipping more reasonable.
If you are unsure what components you are looking at, or differences in types ie, electrolytic vs. ceramic capacitors, do a google search on electronic components. there are tons of great websites out there with excellent information.
Some of the best rescources for information have been beginner books about ham radio. Strange i know, but true.
Hope this helps
KLH DVZ-2500... | Answered on Sep 30, 2009
There is a belt most likely under the tray that has stretched. replace it with the same size and it should be ok.
KLH DVZ-2500... | Answered on Apr 06, 2007
disconnect offending unit. then play see if same response occurs on the alleged normal unit using the offending cable interchange cables see if you get same result. Means it's bench repair ,internal electronics require specialist equipment to locate the offending item.
KLH Audio... | Answered on Oct 31, 2018
You could check it by having the unit switched on a touching each of the pins of the device with an insulated tool. Making certain you don't short any of the pins together. You should hear a buzz on each channel. If you get nothing on the right then it could well have gone.
However that is a lot of messing about, as the device can be purchased for around £12, it could be easier just to replace it and see if that cures it. After all it is the device that does most of the work, so the chances are it's gone!
KLH Audio... | Answered on Oct 01, 2018
KLH DVZ-2500 System Logo
16 questions posted
Popular Products
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • KLH Audio Players & Recorders
Most Popular Question
preset password
  • Audio Players & Recorders
