20 Most Recent
Koss KS3112 DVD Player Questions & Answers
Unit was unplugged for a
hello. I can assist you. Unplug computer for at least 30 seconds.
Once power is restored, enter the following code into your remote: 7- 6- 4- 1- 9, then hit the power button.
This ought to reset the system back to its original function.
I,ve touch a function and
yes , i can help,> open dvd tray, your player will go to menu but it will be jumping so look to bottom of screen to tell what function you are in. scroll down till you see "display lets you display picture etc." when you see this at bottom of screen hit enter and and hit bottom arrow you will see pal/ntsc option hit enter again and your picture will return to normal good luck.
No picture
The machine was inadvertently switched to Prgressive Scan mode which only works if you have the proper cables and receiver.
The following sequence runs through the menus that you cannot see when the mode is incompatible and switches off the progressive scan mode:
Turn machine on (no disc).
Press down arrow 3 times, then press OK.
Press down arrow 2 time, then press OK.
Press OK again.
Press down arrow 1 time, then press OK.
Will not power up
Checa si hay filtros secos en la fuente puede ser uno de 50v a 100mf.
Progressive scan
Algunas veces funciona sacando el disco del dvd y cerranda la charola presiona por 5 o 10 segundos la tecla stop,ojala te sirva.
Koss ks4125 DVD player codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
