20 Most Recent
Koss KD250 DVD Player Questions & Answers
My dvd player koss ks2503
Check the capacitors in the power supply and replace the ones that are large and/or leaking. They usually look puffed up on the top. Also check the solder connections on the power supply. Very common with these "KOSS" units.
I have a picture but no sound
Not much info on the device but check the scart lead by substitution, also they often loosen causing problems so reseat both ends and
check in the setup menu that you have selected the correct audio on the output.
Also does it have a headphone socket? If so plug in your headphones to see if audio is on that.
How to change paasowrd in kos
You can reset the password by pressing stop key on player and remote for about 2 seconds.
To unlock your player:
On your remote commander > press menu . 1 6 7 > mute.
Put your CD on tray > press stop > press menu > press 1> press index then press open
But I don't see the option to change the password
Regards, Jay
Tray not opening
that is probly the loading belt;try open it removed manuallly the disk and open the tirror
and replaced the belt..and by the clean the laser lens
hope that will help
Koss DVD
the humming noice is the dvd spinning trying to read the disc so we know that works take it apart and see if the laser is working d{dont look in the laser} and if that works take a q-tip and lightly wipe off the laser lightly move the laser up and down to make sure its not stuck and try to see if it works then
ps keep it off the carpit
Koss ks4125 DVD player codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
