20 Most Recent
Koss KD260 DVD Player Questions & Answers
Cannot close disc tray
The dealer lock feature was
intended to prevent theft of discs when on display at the retail
location. To shut it off, you press and hold the "stop" button on the
front panel of the player. While holding that, simultaneously press the
"power" button on the remote control. You can release both buttons now.
A message will say "dealer lock off" and now you can eject the disc.
Can not remove dealer lock
The dealer lock feature was intended to prevent theft of discs when on display at the retail location. To shut it off, you press and hold the "stop" button on the front panel of the player. While holding that, simultaneously press the "power" button on the remote control. You can release both buttons now. A message will say "dealer lock off" and now you can eject the disc.
Koss dvd player
Perhaps the sled motor is stuck on the unit. What model number is it? Can you remove the screws on the cover and try to open it manually moving the sled mechanism? (carefully of course, with very little force). It might just need to be lubricated.
Koss ks4125 DVD player codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
