20 Most Recent
Dell OptiPlex 780 PC Desktop Questions & Answers
Dell optiplex 780, cannot make changes in setup
the coin cell batter is dead.
that means save button in Bios 100% dead.
on all PCs made for 40 years
29years of optiplex.
780 is 2012, so not true that. 2 years old
can not make means what?
cant see all BIOS pages
or can not use the save button
ok is BIOS ADMIN PW enabled ?
using keyboard are you?
is this your first time in bios every on any PC .
if yes read the screen prompts carefully
if page 1 , set BIOS defaults falls in any way say so
is PC just bought used dead, and coin cell missing inside
if BIOS defaults fails that means page security ignored by you and passwords were set by others.
Alert! unsupported memory configuration. Please populate DIMM1
There should be 4 DIMM slots - two with white tabs and two with black tabs. DIMM 1 should be the white tabbed slot closest to the processor. Slots 1 and 3 (both white tabbed slots) should have RAM installed first, then slots 3 and 4 for additional RAM. If Slot 1 already has RAM in it, pull it out and push it back in to reseat it. If that doesn't work, replace the RAM in Slot 1.
Rattling loud fan dell optipilex 780
Anonymous,
You may want to replace the fan. You can call the Dell Spare Parts Department at 1-877-717-3355 to purchase a fan.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Restarts continously
Does the system manage to boot at any point? If it does and there is a period before it restarts the system could be overheating. I would ensure all cooling fans and heatsinks are clear of dust/debris.
If you are unable to boot to Windows, try starting in safe-mode. If you can start in safe-mode it will be a strong indication there is problem with your software. At this stage in safe-mode I would first of all try a system restore back to when my computer last worked, if you have no success I would then suggest a virus check/clean in safe-mode.
If you find the system won't even start in safe-mode I would check your RAM is seated correctly, and if that doesn't solve your issue proceed to check/test all other components of the computer. Being a DELL if you press F12 during start up I believe you can ask the system to do a hardware diagnostic test.
Power light amber with code 3 and 4
Looks like Memory Issue,
Memory modules are detected, but a memory power failure has occurred.
You can try as follows :
- If two or more memory modules are installed, remove the modules, then reinstall one module and restart the computer. If the computer starts normally, continue to install additional memory modules (one at a time) until you have identified a faulty module or reinstalled all modules without error. If only one memory module is installed, try moving it to a different DIMM connector and restart the computer.
- If available, install verified working memory of the same type into your computer.
Let me know
Thanks
Error codes
Go to Dell Support > Optiplex 780 Desktop PC > Manuals & Documentation > Dell Optiplex 780 Service Manual,
http://www.dell.com/support/troubleshooting/us/en/19/Product/optiplex-780Diagnostics > Diagnostic Lights,"Problem Description - A possible expansion card failure has occurred""Suggested Resolution -1) Determine if a conflict exists by removing an expansion card (Not a graphics card) and restarting the computer.2) If the problem persists, reinstall the card you removed, then remove a different card and restart the computer"Be SURE to follow Anti-Static Procedures.Regards,joecoolvette
Power supply malfunctioning
Most surge protection power boards will protect computer equipment from mains spikes and surges.A better and more expensive solution is to use an uninterruptible power supply (UPS). These units provide surge and spike protection and also provide power in the event of mains power failure.Make sure you select an UPS model that meet the power requirements of all your computer equipment that is connected to the UPS with a mains down time of say 1/2 hour to give you time to shut down your computer in an orderly manner.
Can't change bios settings
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
