You need Cyberlink PowerDVD software to run a BlueRay Disk. Normally, in Acer computer you should have Cyberlink PowerDVD software, please open the software and follow the below mentioned steps
To update the Cyberlink PowerDVD software:
1. Connect to the Internet. 2. Open the Cyberlink Power DVD application. 3. Click the arrow in the upper left hand corner of the window next to Cyberlink PowerDVD. 4. Click on Update Now 5. Follow the prompts to install the update.
Note: The update process may have to be repeated more than once to ensure the latest version is loaded on the computer.
Reminder: Blu-ray protection software prevents Blu-ray movies from being displayed on both the notebook LCD and an external monitor at the same time.
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
You have to count the beeps to determine what work. Overall if the system beeps on startup it sounds like the memory (RAM) is not working. My suggesting to either buy new RAM or reseat the existing memory by taking about and put back in.
Hi Vassili,
You might want to try this steps. Hope it helps.
Restart your Acer computer to ensure that the drive does not simply need a reset before it can eject the disk. Press the "Eject" button on the drive to confirm.
Straighten a paper clip.
Insert the paper clip into the small hole on the front face of the CD or DVD drive with the computer turned off. As you press the paper clip into this hole, it will manually eject the disc from the drive.
In case you're not able to eject the disc using the eject button or you can try right clicking on the CD drive under 'My Computer' and clicking on eject.
If that fails as well, you can try to eject the disc by pushing a straightened paper clip or a pin into the tiny hole on front of the CD drive. You should be able to eject it using the last method.
GuruAid
If video is not working remove and re-install drivers. if video download is not working clean up browser. further if you have problem please explain more.
this seems to be the fault at the service centre. contact directly to Acer Support and log a complain. don't forget to to take the complaint ID or ticket #
