20 Most Recent Symphonic CD5800 CD Player Questions & Answers
What is a good laser cleaner to use
I assume you are refering to the laser in a CD drive. Use 97% isopropyl alcohol. Put a drop or two on a Q-tip and wipe the dust off the lens. Let the alcohol dry completely before reassembling the drive.
2/9/2015 5:31:53 AM • Symphonic CD5800... • Answered on Feb 09, 2015
Player won't read disk. What can I do?
Does it make mechanical noise while it is trying to read a disc? That would indicate a laser out of adjustment trying to focus. Otherwise you may just need to clean the lens with some rubbing alcohol and a q-tip. Let it dry well before you fire it up again. Most player issues are due to a dirty lens and most disc style lens cleaners are only meant to be used as a maintenance item.
2/9/2015 4:48:31 AM • Symphonic CD5800... • Answered on Feb 09, 2015
manual
manual
0answers
Replaced lost remote with n9170ud and need code
you shouldn't need a code for that. it is the OEM remote for that CD player. if it doesn't work, id say its a broken remote, return it and buy another one or a universal remote with a learning function.
3/8/2011 10:47:04 PM • Symphonic CD5800... • Answered on Mar 08, 2011
0answers
Connecting to speakers
There is no built-in amplifier on your cd-player so you cannot connect speakers directly to the CD player unless they are self-powered(like the speakers for a computer) so you will need to connect the red and white rca jacks to the television's audio input jacks, an external stereo reciever, or self-powered speakers to get sound from the cd player.
12/21/2009 3:27:05 PM • Symphonic CD5800... • Answered on Dec 21, 2009
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered 17 hours ago
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
Symphonic CD5800 CD Player Logo
Popular Tags
12 questions posted
Popular Products
Top Symphonic Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Symphonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Audio Players & Recorders
Most Popular Question
good laser cleaner use
  • Audio Players & Recorders
