20 Most Recent Acorn Stairlifts Acorn Superglide 120 Stairlift Questions & Answers
2answers
Where do the wires go to from the on/off switch on an Acorn stairlift
Question moved from Cars and Trucks Wiring for THIS model is on Page18 https://fccid.io/2AFDQACORN180REMOTE/User-Manual/Users-Manual-2699943 ..
10/6/2023 7:00:29 AM • Acorn Stairlifts... • Answered on Oct 06, 2023
2answers
Acorn 80 stairlift new batteries, line top and bottom, 30 seconds off doesn't work. won't move to top
moved from cars/trucks to lifts. call for service, see users manual last page 800 nnnnnnnn call.
10/6/2023 6:56:48 AM • Acorn Stairlifts... • Answered on Oct 06, 2023
I am repairing a American Stair-Glide 37 indoor model stairlift and need a wiring diagram. It's a 110 volt system. Norm in Lexington, Ky.
Question edited for clarity. Question moved from Motorcycles. Installation manual and a link to the maker https://www.google.com/search?q=american+stair-glide+37+wiring+diagram ..
3/25/2023 7:30:24 PM • Acorn Stairlifts... • Answered on Mar 25, 2023
Code f7 showing & chair won't lift
Going to the user's manual: https://www.ameriglide.com/cache/1475784382000/resources/product/615/productDocument/292.pdf I see that the F code indicates that there is a fault at the motor, possibly corrected by doing a "reset". Directions are in the user manual. The 7 indicates a fault at the "downside safety edge", the little micro-switch on the downhill side of the footplate. See if there is something holding that little projecting piece of plastic that triggers the micro-switch from springing back out to its normal position. Good luck!
3/22/2019 8:33:11 AM • Acorn Stairlifts... • Answered on Mar 22, 2019
Good morningI have a problem with this stairlift, i probably it should be programmed know the procedure? The electronic board has no switch is the T565 model. O
Hello, Ale112002 - I hope I am correct in thinking your stair lift is an Acorn model 180. This is the link to the Acorn 180 user manual (PDF format, Adobe Acrobat Reader software needed - free); https://fccid.io/2AFDQACORN180REMOTE/User-Manual/Users-Manual-2699943 It looks like a key is needed to turn the unit on and off. The switch for moving up or down is on the right side arm. Is that what you are asking about? If my reply does not answer your question, I suggest you contact the Acorn dealer nearest where you reside and ask your question. Best wishes.
1/1/2019 7:02:10 PM • Acorn Stairlifts... • Answered on Jan 01, 2019
Acorn 120 Lift only goes down and not back up
It sounds to me that you have a cable break somewhere between the armrest controls and the electronics below the seat. I am assuming this is the case as you did not mention a problem with the remote control (if this one has that). If you have a remote control, and neither the armrest or remote work, then the problem is very likely in the motor control electronics.
11/18/2017 10:47:52 PM • Acorn Stairlifts... • Answered on Nov 18, 2017
Lift is slow accending low battery power
Replace the batteries. Easy as that. And it's not that difficult if you go about it logically and slowly so that you don't run into too much frustration. The hardest part is getting the plastic housing off and back on. There are some videos on Youtube on how to do it. You can order new batteries on Amazon for under $20. I just replaced ours and opted for the more expensive Yuasa brand batteries so I wouldn't have to do it again for a long time, but even the cheapest batteries should restore operation for at least a year or two under moderate use. The brand of battery that came in our chair was Genesis.
12/24/2016 7:24:41 PM • Acorn Stairlifts... • Answered on Dec 24, 2016
4answers
No power to unit------could it be I need new
888-563-0410 is customer support Acorn Stairlifts how to videos
12/18/2016 4:00:48 PM • Acorn Stairlifts... • Answered on Dec 18, 2016
Acorn toggle swtich keeps breaking
Replace it with a heavier duty one or stop being so heavy handed; it only needs a light tough, and it won't go any faster if you press it harder! Oh and don't pay the ridiculous prices asked by repairers. Is it spring loaded or just on/off? You cn get a replacement switch from an auction site for about a sixth of the price. Also why is it breaking off, is it hitting something on the way? If you've had it replaced previously call them back?
7/14/2014 5:15:10 PM • Acorn Stairlifts... • Answered on Jul 14, 2014
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Istar x 20000 USER MANUAL
Help in the link, but the one good site doesn't like my Ad Blocker! https://www.google.com/search?q=Istar+x+20000+USER+MANUAL ..
12/23/2023 11:37:12 PM • Electronics -... • Answered on Dec 23, 2023
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
12/22/2023 5:44:02 PM • Electronics -... • Answered on Dec 22, 2023
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
12/22/2023 5:29:39 PM • Electronics -... • Answered on Dec 22, 2023
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
11/28/2023 5:52:33 PM • Electronics -... • Answered on Nov 28, 2023
Acorn Stairlifts Acorn Superglide 120 Stairlift Logo
21 questions posted
Top Acorn Stairlifts Electronics - Others Experts
goneforever.
ADMIN Andrew
ADMIN Andrew
Are you an Acorn Stairlifts Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Acorn Stairlifts Electronics - Others
Most Popular Question
chassis wiring stanna 420 stairlift
  • Electronics - Others
