20 Most Recent Microsoft MSN Messenger Connect Service Questions & Answers
Getting an error 80072f19?
Start IE & select Menu - Tools - Internet Options - Advanced
Under Security Section - Clear the "Check for server certificate revocation (requires restart)" check box
Start MSN Messenger beta 7 again & you'll have to issue your passport account information again. You'll receive one more error. Login again and it will work.
Microsoft MSN... | Answered on Sep 04, 2019
It is a recover process. you will be recover your account for unblocking account. I am sharing you few steps with the help of this steps, you can recover your account.
1. Go to Microsoft site
2 Select on recover account and reset password.
3. Enter your block account and type the character you see on your screen and click on next.
4.Now enter the code generated by authentication app or select use a different verification to get a text message.
5.After the all process , you enter the security code, and you should change your password to complete the unblocking process.
Hopefully these steps solved your problem.
Thankyou.
Microsoft MSN... | Answered on Nov 20, 2018
click on the "forgot password and or screen name" it will email you a new password that you can change it back to what you want in your sign on settings when you get back in.
Mel
Microsoft MSN... | Answered on Sep 25, 2017
You may have to download Framework software from Microsoft.
Microsoft MSN... | Answered on May 25, 2017
ash,
What is your question you need manuals etc, i cant tell from your comment.
Microsoft MSN... | Answered on Dec 07, 2016
msn is now bing you will have to login on bing. here click on sign in option then click on forget password
now write your live or msn id and write 6 special charecters. form here you can reset your password
Microsoft MSN... | Answered on Oct 20, 2016
I don't condone spying but what you need is a KEYLOGGER program. Where to find one and how to use it is up to you to look for. If you need to spy on the person you want to become your life partner, i think you should end the relationship and find someone else.
Microsoft MSN... | Answered on Jan 20, 2016
You are probably having this issue due to an outdated MSN profile. It can also occur when a corruption has occurred to your account settings in the MSN software. To resolve this, you may just need to update your MSN account information. Here's how:
1. Open Internet Explorer then go to www.support.msn.com then sign in to your MSN account
2. Once signed in, click 'çhange MSN Profile' at the left of the page. Your account information will then be displayed. Please make sure everything is correct.
3. Click 'Save' below the page even when you did not change any information in your account.
After updating your MSN profile, try to sign in to MSN again.
If you are still unable to sign in, then you need to remove and re-add your account in the MSN software.This resolves most sign-in issues. However, the process of removing an account from the MSN software may delete the messages saved on folders on your computer so creating a back-up is necessary. For a detailed procedure of backing-up messages, removing and re-adding your account, I suggest that you contact the MSN Technical Support at www.support.msn.com. They can give steps appropriate for your MSN version. =)
Microsoft MSN... | Answered on Aug 24, 2015
Most Routers have a Ethernet port on the back. You can run a cable from the router to the living room and plug the computer into it.
Microsoft MSN... | Answered on Jan 10, 2015
You don't subscribe to Bing, it is free. You just stop using it as a search provider. Remove it from your browser by disabling it.
All tools, counts for the use of field service software to, can help in the job. But for all the tools you use, you need to learn how to use them. It is not because everyone has a computer, they can use every program and put in the correct data and interpret the out coming data correct.
Every one has at least one knife in the house. Only a few can use knives to make beautiful sculptures and only the really skilled can operate on a human being.
You can try to carve a nice sculpture, to find out what your artistic skills are. You would not allow you neighbour to operate on you. So why would an untrained person try to use software if he is not trained in to use it?
Sorry if I did interpreted your question wrong.
Microsoft MSN... | Answered on Oct 07, 2014
Click the "Can't access your account?" link on the Hotmail sign-in page.
Microsoft MSN... | Answered on Sep 23, 2014
Dear Anonymous User
I think as a new computer user it appears you may be confused between your default Web page and your internet browser.
From your comment it appears you may be using and Windows Computer with InternetExplorer as your web browser and MSN has been set as your default web page.
In order to change your default web page Proceed as follows:
Open an instance of your InternetExplorer
Navigate to a Web page you would like to use as your default Web Page
On the right hand side of your browser you will see a symbol of a cog wheel which represent the Tool options of your browser.
Click on the Cog and select Internet Options from the drop down Menu that appears.
On the General tab you will see the address for your default home page.
Click the button Use Current and the the address of your new home page will be displayed in the box above.
Go to the bottom of the Internet Options Page and click the Apply button.
Close your browser.
Open your browser again and you will find your preferred home page is now your default Home Page
Microsoft MSN... | Answered on Sep 21, 2014
You should be able to log into hotmail.ca (canada) and create your new email address there.
Microsoft MSN... | Answered on Aug 25, 2014
Are you developing it so people can login with there id's.
Please review
Windows Live Messenger Connect Developer Guide Version 4 1
If not please give more details to your issue
Microsoft MSN... | Answered on Aug 12, 2014
Go to this link and recover your password by going through the steps. https://account.live.com/ResetPassword.aspx?mkt=EN-US
Hope this helps.
Microsoft MSN... | Answered on Jul 03, 2014
Computers & Internet Logo
196 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
technical support manuals
  • Computers & Internet
