20 Most Recent
Konica Minolta Minolta FAX3900 Digital Copier, Copier/Fax Machine 16 ppm printing and up to 600 dpi resolution, rec... Printer Questions & Answers
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
How to print a fax confirmation?
USER MANUAL
Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report
The document number, recipient name, date sent, starting time of transmission,
number of document pages, time required, mode.
RX Result Report
The document number, caller name, date received, starting time of reception,
number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60
transmissions/receptions.
Minolta Fax 3900 problem at work
I have a Minolta Fax 3900 and it at times while trying to send a fax will say *tx cancel* and only send 2 pages of a fax. It appears like it does send the fax but it might not be the complete fax. I can't cancel the fax or stop it either. Does anyone know how to fix this problem.
