20 Most Recent
MinoltaFax 2600 Printer Questions & Answers
On my fax Minoltafax 2600, I have the following
Polygon is the motor that is located inside the FAX print hear which is where the LASER is located. Have a technician (Konica Minolta) have him check the connection between the print head and its control board. If not need a new print head or worse the control board for the whole machine.. The polygon motor is what makes the LASER beam move across the drum to place the image on the drum, it travel around 35.000 RPM, you mite heard it as very high pitch as gets up to speed. So the LASER and the Motor are inside the PRINT HEAD. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
How do i get a activity report printout from two
Far as I know you can access every report since machine was purchased. Just go into menu as you would for current report printout. There should be an option there to REPRINT PREVIOUS reports or ARCHIVES. Choose the one you're looking for and VIOLA.
Hope this info was helpful to you. Good Luck!
MinoltaFax 2600
bad phone cable, bad phone line or modem malfunction, try another phone line, test phone line with an phone, can you call out? Unplug machine for a couple of minutes to see if modem resets.
Hope this helps.
Ed
I dont have a driver 4 my minoltafax2600 can u help me?
Please find the free driver download link below for you Minolta fax 2600, FAX/printer below:
http://www.printcountry.com/drivers/MINOLTA_FAX_2600_DRIVER_DOWNLOAD.htm
Open the page and select the product and the operating system installed on your computer to start downloading the FAX/printer drivers, once the driver software is downloaded install the driver, however please make sure that you do not connect your FAX/printer to the computer until the installation wizard prompts you to do so.
Should you require any further assistance regarding the printer or even require assistance regarding any other computer related issue in future please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
