20 Most Recent
1990-1993 Accord 2 and 4 Door Body Kit Part 5460 Questions & Answers
Car wont start
Has to be electrical or fuel related. spark and gas the basic places to start! good luck! Remove the gas line at the filter and use a can to catch the gas turn it over and see the volume of gas before and after the filter. Remove a spark plug and ground it to the closest metal or buy a spark plug tester [preferably] then turn it over check for spark. Don't be holding plug wire HEI has a bit of a bite! I could be wrong but a good place to start. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/jeff_24365d731679262d
Lightbulb replace hondaaccordradio1998
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
