20 Most Recent
Minolta DiALTA Di620 All-In-One Laser Printer Questions & Answers
Error code C-14F2
Check the filter operation and harness and, if they are okay, change PWB-IB or PWB-IC meaning check the connections one board B is located under the scanner C is located behind the scanner, get tech to this is is going to get complex open close front door to reset. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Error c-0072
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Btw, I’m available to help over the phone in case u need at
Dialta 620 error code c-0120
Directly below the drum is a assy. that has two very fine wires in side of it that have several thousand volts applied to them during the copy/print process. and what might have happen is that they broke or the end assy. blocks that hold them have begun to break down due to old age check the wires replace them if required replace the end blocks or get whole new assy. Btw, I’m available to help over the phone in case u need at
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Error code C-004A
C004A
Exposure fan problem
You will have to take this printer in for repair. Unless you can remedy yourself?
