20 Most Recent Minolta magicolor 7300 Laser Printer Questions & Answers
Magenta colour leaving lines on pages.
Replace the magenta image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/26/2015 1:16:03 AM • Minolta... • Answered on Dec 26, 2015
Format on first page of document is always mis
In correct paper size check that you are using inch not metric paper sizes Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 8:25:47 PM • Minolta... • Answered on Mar 01, 2015
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/17/2015 1:39:21 AM • Minolta... • Answered on Feb 17, 2015
How do I override colour ink level to use as monochrome
can you go into the printer properties then preference's or the gear box change to grey scale printing only??. I can do that with my Cannon so saving on using the colour cartridge...hope this helps
2/7/2012 7:47:08 PM • Minolta... • Answered on Feb 07, 2012
All toner cart's replaced, new toner heads about
(1) If it takes developer as well as toner you will need to change the black developer.
(2) Also check the voltage is correct
(3) check that the toner path is not blocked
lets know how you get on
2/23/2010 11:18:28 PM • Minolta... • Answered on Feb 23, 2010
Can I find PCL drivers for Windows 7 ?
From the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=magicolor%207300
select the device-driver for Windows 7.
1/7/2010 8:13:46 PM • Minolta... • Answered on Jan 07, 2010
Minolta 7300 - tearing through consumables
I've had the same issue with this printer. Are you using Minolta own brand cartridges? You should be.
It sounds like it is wasting a lot of toner. You'll need an engineer to check the drum mechanism.
8/11/2009 11:56:53 AM • Minolta... • Answered on Aug 11, 2009
Download toolbox 940c
For what model sir/mam? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/8/2015 4:31:46 AM • Minolta... • Answered on Feb 08, 2015
Pagemaker 7 0
Are all of the image unit and color toner Minolta/QMS (OEM) not third party. Does the machine print the demo page OK? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 11:03:24 PM • Minolta... • Answered on Feb 04, 2015
Konica minolta magicolor 8650
What about the machine showing a code or image problem you did not state the problem when you submitted the question. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 10:55:31 PM • Minolta... • Answered on Feb 04, 2015
Konica minolta printer problems
What model and code is it displaying Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2015 12:47:20 AM • Minolta... • Answered on Jan 23, 2015
Printer is printing all the pages on top of each other
What is the model and what is make? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/22/2015 11:23:38 PM • Minolta... • Answered on Jan 22, 2015
Paper size error on 1690mf
Machine mite be set for metric paper and computer printing in inch Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2014 10:38:04 PM • Minolta... • Answered on Dec 29, 2014
Minolta EP1050 CS Pro. It is stuck in A3 lengthways mode, I was copying in A4, wanted to go to book mode, pressed button but machine became stuck in A3 lengthways mode instead.
Change it back. Here is your manual. https://www.manualslib.com/manual/1001522/Konica-Minolta-Bizhub-Pro-1050.html?page=110#manual There is also a Service Manual available for it if you ever need it.
MINOLTA EP1050 GENERAL Service Manual download ...
Elektrotanya https://elektrotanya.com > minolta_ep1050_general.pdf Download MINOLTA EP1050 GENERAL service manual & repair info for electronics experts. ... MINOLTA EP-1080 CS-PRO A3-COPIER 1993 SM service manual. MINOLTA EP-1080 ... ..
10/4/2023 4:52:00 PM • Minolta Office... • Answered on Oct 04, 2023
Konica Minolta Bizhub C203 Color, Laser MFP. It jams paper, I have checked it and have even changed the fuser unit, but still the same thing. Please what can I do?
Question edited into written English. Misfeed Error, or Timing Error. You need dealer service. This is a Professional Machine. The fuser only heats the toner to set it on the paper. It is nothing to do with jams.
3/16/2023 2:13:56 AM • Minolta Office... • Answered on Mar 16, 2023
I have a c3513 error code on my kondica minolta bizhub pro 1060L. Does anyone know what this means... thanks Anthony
Yes the Fuser unit that part that is very hot well one of the sensors has detected a very hot temp. get a tech out o look at and reset it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/17/2023 1:37:14 PM • Minolta Office... • Answered on Feb 17, 2023
Hi i have minolta Dialta 520 Photostate machine
The error code C-1028 on a Minolta Dialta 520 photostat machine typically indicates a problem with the paper feed system. Based on your description, it seems that you have already replaced the PWB-B Board and checked all jacks, but the problem persists. In this case, there could be a few other potential causes of the error.
  • Paper feed motor
  • Main control board
  • Gears or other parts in the paper feed system
  • Paper feed sensor
Regarding the Bet Pin, it could be the name of a specific pin on the PWB-B board or in the paper feed system, but without more information about the specific location or context it is hard to say exactly what it is referring to. It is recommended to consult the service manual of the machine, or contact the manufacturer or a professional technician for further assistance. They will be able to diagnose the issue and provide the necessary steps to fix it.
1/21/2023 10:56:22 AM • Minolta Office... • Answered on Jan 21, 2023
What is the meaning of call for service 001 on Minolta 190f
Something to do with main motor. paper jam. Or bad main motor.
11/6/2022 5:23:20 PM • Minolta Office... • Answered on Nov 06, 2022
Minolta magicolor 7300 Laser Printer Logo
7 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Minolta
  • Magicolor Minolta
Most Popular Question
override colour ink level use as
  • Office Equipment & Supplies
