Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
- With the ignition on and radio OFF,
- Press and hold the MULTI-CONTROL button for 2 seconds
- Rotate MULTI-CONTROL button until display reads CLOCK.
- Push MULTI-CONTROL button up or down to adjust hour and minutes.
- Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
- With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
- (If you do not have a function button, use the AUDIO button instead).
- Press the FUNCTION button again until the clock shows on the display.
- Press the UP and DOWN buttons to adjust the hours.
- Press the LEFT and RIGHT arrows to move to the minutes.
- Press the UP and DOWN to adjust the minutes.
When you've completed all the steps, just press the SOURCE button to exit.
If your car CD player is 1999 or older:
- While holding down the CLOCK button, press the number preset button to set the hour.
- While holding down the CLOCK button, press the number 2 preset button to set the minutes.
- Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the
radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
