20 Most Recent
Danze opulence" Single-handle Kitchen Faucet With Pull-out Victorian Spout Questions & Answers
How do I clean strainer i Danze pull out kitchen faucet?
The faucet came with a weird-looking tool which has two protrusions the exact width of the two grooves in the head of the faucet. You place the tool prongs in the grooves and then unscrew the strainer lefty loosey. To get a replacement free, just call Danze or an authorized dealer--they have an honest-to-god lifetime warranty, and will send you the tool and needed replacement parts Free. I was amazed.
How to install danze model d404554
Hey! Danz, KWC and Glacier Bay are all junk that's made in China with no repair parts. Don'cha think so? No? Well here's a list.
http://starcraftcustombuilders.com/sources.faucets2.htm
See where you Danz lies: 17% happy faces is all. Why cause they're cheap China junque, junk, jonk, however you want to spell it, it's a junk!
Clogged hot waterline
This is one possibility that when the water line was hooked up to the shut off valve a piece of Teflon tape may have gone over the threads off the pipe that prevents the line from leaking and is restricting the flow of water to the spout .check all connections
Water dripping faucet
If the cartridge has a gasket, it should also be replaced. Another common problem in hard water areas is the buildup of lime. See if there are deposits which may cause a bad seal and, therefore, a leak. Hope this helps.
Faucet loose in side
If you installed the faucet you need to use a basin wrench to make the nuts tighter under the sink and this will stop the movement. Some fauect have a large nut with two set screws on each side. Then you just make the nut hand tight and then take a screw driver and then make those two set screws tight and then the inside will pull tight
Best of luck
RJ
How do yoy remove the
remove the center cap and under that is a screw back that out and then use a handle puller to take the handle off this puller will stop damage to the stem and the handle
Best of luck R J
