20 Most Recent OKIPAGE 8z Led Printer Questions & Answers
Oki Data Americas, Inc., today introduced the ultra-compact OKIPAGE 8z Digital LED printer, a high-performance, practical alternative to inkjets for personal, business-class printing. The OKIPAGE 8z is the ideal printer for any desktop -- in your corporate office, your home office, Classroom or dorm.
With a suggested retail price of $249.00 and sharp 600 dpi-class output, the OKIPAGE 8z is an 8 page-per-minute (PPM) digital LED monochrome page printer designed for business professionals.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
OKIPAGE 8z Led... | Answered on Feb 24, 2011
U need to go on the program in your computer and from there reset the drum, probably u have one called okidata, ther u have a OP8z monitor.
OKIPAGE 8z Led... | Answered on Jan 17, 2007
Error code 122 means " Low voltage FAN error ".
Is the FAN (bottom right of the front) of the low voltage power supply block working? Is the FAN connector connected correctly?
Check to make sure connection of the FAN connector. Replace the low voltage power supply unit. Replace the FAN motor. Replace the low voltage power supply unit.
Source: https://www.okoki.co.uk/how-to-fix-oki-printer-error-codes
OKI Office... | Answered on Jun 16, 2019
in case you need it ....The Administrator log in for the menus s :admin pw: aaaaaa
your answer is here:
http://www.manualslib.com/manual/916780/Oki-Mc361.html?page=19
OKI Office... | Answered on Jun 14, 2019
Sometimes if there was a paper jam and someone removed it without getting all of the paper, then there could be a small piece of paper still in the way of the sensor. If you have any compressed air it might help to blow it out of the sensor area. I have had issues with that in the past as well, so I opened up the area it said it was jammed - gave it a good going over with the can of compresses air, and it seemed to clear out the jam.
OKI Office... | Answered on Apr 18, 2019
It could be a re-allocation of IP address. The best solution to that is to allocate the printer a specific permanent IP address and but the same setting into the port address for the machine on every PC using it
OKI Office... | Answered on Mar 18, 2019
Please feel free to contact our customer service number +1-(845)-477-5334 to fix all Oki Fax product related issues
OKI Office... | Answered on Feb 12, 2019
The printer seems to have both USB and ethernet connections therfore any PC or Mac should be able to connect without any problem. You will need to install the compatible driver for your peeing system. This can be found on the manufacturer website. Hope it helps
OKI Office... | Answered on Jan 17, 2019
power down the printer for 30 minutes. remove and then insert the magenta toner. power on.
OKI Office... | Answered on Jan 08, 2019
OKIPAGE 8z Led Printer Logo
Popular Tags
7 questions posted
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • OKI Office Equipment & Supplies
Most Popular Question
resetting image drum
  • Office Equipment & Supplies
