20 Most Recent OKI C3200n Led Printer Questions & Answers
When the paper prints, the color is missing in
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
7/15/2017 9:17:00 PM • OKI C3200n Led... • Answered on Jul 15, 2017
Okidata C3200N
It would help if you said where the paper jam was. However the fact that it was ok until you cleared the jam indicates you have knocked something out of place. Its just possible one of the high voltage contact springs that touch the drums has stuck in and no longer makes contacts with one of the drums. Make sure all the semi circular springs move in and out freely. Also check the led heads in the top cover. Make sure all the cables are seated in the heads ok. Make sure all the heads are in the same position and one has not turned around. Retrace your steps as your drums seem to be problem.
6/25/2017 9:10:12 PM • OKI C3200n Led... • Answered on Jun 25, 2017
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
5/28/2017 1:05:51 AM • OKI C3200n Led... • Answered on May 28, 2017
2answers
Drivers for a C3200 Oki laser printer to go with an Apple MacBook
Here are Mac drivers on this link:
http://my.okidata.com/DSDownWeb.nsf/(MOC-C3200n)?OpenView&Start=1&Count=30&Expand=12
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4/18/2017 12:26:59 PM • OKI C3200n Led... • Answered on Apr 18, 2017
What is the cause of OKI C3200n fatal error 173
Fatal error code 173: This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows: 140 - Yellow Drum Up/Down error 141 - Magenta Drum Up/Down error 142 - Cyan Drum Up/Down error Solution: 1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage. 2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums. 3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
3/23/2015 10:19:51 PM • OKI C3200n Led... • Answered on Mar 23, 2015
How do i print borderless
you cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
1/8/2015 2:47:51 AM • OKI C3200n Led... • Answered on Jan 08, 2015
0answers
Md471w
Be the first to answer 4/9/2014 3:43:06 AM • OKI C3200n Led... • Posted on Apr 09, 2014Be the first to answer
0answers
0answers
4answers
Epson PX700W has a paper jam warning - won't clear
unplug it for about 10 minutes and plug it back in
3/12/2013 7:51:23 PM • OKI C3200n Led... • Answered on Mar 12, 2013
Windows 8 says my oki c3200n is in an error state
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
1/28/2013 4:11:46 PM • OKI C3200n Led... • Answered on Jan 28, 2013
0answers
OKI C3200n Led Printer Logo
Popular Tags
112 questions posted
Popular Products
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C OKI
  • C OKI
Most Popular Question
windows 8 says oki c3200n in error state
  • Office Equipment & Supplies
