20 Most Recent
Pioneer DEH-1500 CD Player Questions & Answers
I want to connect my ipod to the aux inputs on back of unit
Hello gcd_sun,
The RCA jacks on the back of the Pioneer DEH-1500 are preamp outputs, not inputs. They are to connect an external amplifier for additional speakers or subwoofers.
The output from your iPod is probably "bleeding over" into the receiver detector stage. When the antenna is disconnected, the signal passes into the amp by itself. Connecting the antenna provides enough signal so that both are amplified.
To connect the iPod, you need to purchase a wireless iPod adapter, or a new head unit that includes an "AUX" input or a dedicated adapter for the iPod.
Hope this helps.
Mute
Unfortunately, this unit does not have a cell phone mute feature, so you will not be able to do it using the deck. You will have to look into an external solution.
I need to know the color coded wires for a car
The power color is red,the negative lead is black,the constant power is yellow.Now for the speakers ,the white lead is the + and the white with the black line on it is the - wire ,grey wire + and grey with black line wire - ,green wire + and green wire with black line wire -,purple wire + and purple with black line -.Hope that clear your mind.
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Found a posting on another site from 2005, and it worked!
Turn on the radio. Press and hold the "Source" button until the radio goes off. Press and hold the "Audio" button until the numbers flash. Use cursor/arrow buttons to adjust the time. Press and hold the "Audio" button to exit.
I had to buy another
Are you sure you have the correct face for the radio. Most pioneer faces are not interchangable.
