20 Most Recent
Rangemaster Professional 90 SS (electric) Kitchen Range Questions & Answers
I have just moved into my new home with a fitted
Use a good thermometer, if possible a probe type to check heat after oven is turned on , Now at different timing take the test while switching off oven or heating till the set levels of temperature can be marked and calibrated on the panel with the marking in place.
You can start by calibrating from 90 degrees and in steps of 30 degrees making sure it is marked with the set levels.
Thus it can be calibrated to work.
No power to main oven or either oven light
check your main panel for 240volts and again at plug in on unit,unless you have some power i.e. 120volts, you need 240volts to operate oven, also check neutral on supply line into oven/lights,thats open nothing will operate
I have a Rangemaster Classic 90 dual fuel that has problems igniting the gas hob.
Remove the flame spreaders and rings from the 3 rings you use the most, including the faulty one. Put them in a large pan cold water, add a teaspoon of dish liquid and slowly bring to a simmer. As soon as it want to boil over, blow on it and turn the heat off. Leave it to cool. Scrub with a plastic pot brush making particular attention to the holes. You had a blocked one which is the one that directs the gas to the spark igniter. Rinse and dry them, and replace to the hobs.
