20 Most Recent
Polaroid a930 Digital Camera Questions & Answers
My polaroid a930 digital camera won't download pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
My a930 polaroid does not focus well at all what
This could very well just be the nature of the camera-- are you attempting to take pictures in low light? This can cause difficulty for the camera to focus. If the camera is having trouble focusing in broad daylight, then there is likely some problem with the autofocus system that would need to be examined by a camera repair shop. The repair on a point and shoot camera like this one would likely exceed the value of the camera.
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
