20 Most Recent
GE X5 Digital Camera Questions & Answers
How do I transfer my photos from camera to
First of all computer need compatible camera driver/software to communicate with your device (camera), you can download camera driver from its manufacturer's (camera) website. After installing camera software/driver into your PC (Computer). Connect your camera with computer through USB Cable that came up with the camera and transfer photos.
Thanks...!!
What does white protect means
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a GE X5 Digital Camera how do I change from internal pictures to my sd card
1st I am surprised it didn't reset it's self when you re-inserted the card. Go into the menu and under the second to the last icon to the right is a place to change back and forth from internal to SD card. That is the only suggestion I have. My camera takes great pictures but can be temperamental- for nearly a year it simply would not turn on. I had given up on it and only gave it a try when preparing to get rid if it.
What is forced flash
"Forced flash" is when you force the flash to fire even if the camera thinks there's enough light to photograph without it.As an example, consider taking a photo of a person outdoors with the sun coming from one side and casting half the face in shadow. By forcing the flash to fire, you can illuminate the shadowed portion without affecting the background.
