20 Most Recent
Olympus T100 Digital Camera Questions & Answers
More than 200 photos have just vanished from the sdcard.They were not deleted.How can I retrieve them?Are they lost forever?
Yes it is possible... You need to use a photo recovery program immediately. EaseusPhoto is free ...you must do this ASAP before the computer writes any more stuff to hard drive.choose complete recovery and allow the program to scan the entire hard drive.It will list all found files.these will not have the original file names...you may find some images truncated due to blocks being overwritten by computer since reinstall.here's the thing once it finds all the jpegs that were deleted you need to save them on to other media such as external sad card reader or hdd as it may not allow you to save found files on to the hard drive you searched.
HOW CAN I APPEAR THE DATE ON THE PHOTO?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
How can I remove the lock on olympus t100
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
T100 usb
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Can i use it witout battery charger
Hello sai,Of course you can use your camera without the battery charger but when the batteries empty then you will need to purchase batteries which is a lot waste of money. When purchasing rechargeable batteries the charger comes free.
Iwont to juse this camera to sow pictures in
There are red ,yellow and white input plugs on this.
put the yellow on the yellow, and the white on a white one.
Something might already be in those plugs, so you might want to unplug something.
Please rate this answer
