20 Most Recent Frigidaire FGHD2433KF Builtin Dishwasher Questions & Answers
Won't drain. Already replaced the drain pump and checked for clogs. Still doesn't drain.
Dose the pump run? If not Is the pump getting power? if not Check the triac on the cpu If OK check pressure switch
3/27/2015 12:45:11 PM • Frigidaire... • Answered on Mar 27, 2015
Door Gasket keeps coming loose on Frigidaire FGHD2433KF. How Do I keep it in? Glue?
Good Morning friend, thanks for your post!
From the information you have provided the door gasket on your Frigidaire dishwasher continues to come loose. Typically, when your gasket starts coming out you may need to have a replacement gasket installed. I would recommend operating the gasket you need from your manufacturer and replacing it. I hope this information is helpful. -Matt
3/4/2015 2:47:15 PM • Frigidaire... • Answered on Mar 04, 2015
Water will not drain.
Hi Ruthp53, I am JK. I see that you have installed a new garbage disposal and now are having problems with your dishwasher (model FGHD2433KF) draining. I would recommend checking for blockage at garbage disposal and the drain. Also, new garbage disposables normally have a plug that will need to be taken out. Hope this helps!
3/13/2014 8:35:11 PM • Frigidaire... • Answered on Mar 13, 2014
0answers
Doesnt turn on
Do you have any flashing lights or beeps? Did you turn the household circuit breaker for a few minutes?
1/5/2014 6:52:57 AM • Frigidaire... • Answered on Jan 05, 2014
FGHD2465NW1A Frigidaire dishwasher smells fishy
I'd recommend using Affresh Dishwasher cleaner, as seen here;http://www.reliableparts.ca/product/inv_9260845/Appliance-Cleaners-467052
10/8/2013 3:12:23 PM • Frigidaire... • Answered on Oct 08, 2013
Frigidair dishwasher model fphd2491kfo wont drain
Good Afternoon Tyler, thank you for your question! Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and then lifting it out. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then there is a possibility that the drain motor may need replacing after a proper diagnosis from an expert. You can locate a certified technician directly through the manufacturer website or in your local directory.
8/29/2013 6:21:10 PM • Frigidaire... • Answered on Aug 29, 2013
Dish washer will not fill
Good Afternoon Joe - Based on the symptoms you are describing, it sounds like the hoses could be kinked or blocked or clogged water screens. If you've cleared the water screen and/or unblock any kinked water hoses, and the problem still persist after the previous troubleshooting and repairs, the unit may need a main control board replacement. At this point, I would recommend contacting a professional for a further evaluation.
6/7/2013 5:50:39 PM • Frigidaire... • Answered on Jun 07, 2013
Middle arm loose
Hello Mike Hilgers - There are two main reasons why the middle spray arm could possibly be loose. Either it is not installed properly or the bracket that mounts it to the bottom of the rack is broken or loose. Carefully remove rack, spray arm and reposition correctly with all rack wheels inside rack slides. If you have already done so, replacement parts may need to be ordered or it could possibly be a more serious issue coming from the interior dishwasher.
3/8/2013 7:14:02 PM • Frigidaire... • Answered on Mar 08, 2013
No indicators lights are showing and I cannot get the unit to start - checked all breakers, switches and plugs. Is there a reset button I may be missing?
Hi kwitt - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, confirmed that the door is properly latched and restart unit. If it proves to be ineffective, then the unit may possibly have a more serious issue like a wiring failure, faulty door latch or control board. I suggest contacting a professional to move forward accurately.
2/10/2013 10:11:20 PM • Frigidaire... • Answered on Feb 10, 2013
0answers
Eu error code
Be the first to answer 1/28/2013 6:16:06 AM • Frigidaire... • Posted on Jan 28, 2013Be the first to answer
PF, high temp wash and air dry lights blinking. Reset main breaker but no help.
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
1/8/2013 5:57:38 PM • Frigidaire... • Answered on Jan 08, 2013
Dishwasher is making noise likes it running and I haven't pushed any buttons. Cycle had said it was complete, I emptied dishwasher and when I closed door it sounded like it was running. I have tur
Hello seagraves98 - Since you have already confirmed that the spray arms are moving freely and the filter has recently been cleaned, I will suggest verifying that there is enough water pressure coming into the unit. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
11/30/2012 6:58:47 PM • Frigidaire... • Answered on Nov 30, 2012
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
11/28/2012 6:33:12 PM • Frigidaire... • Answered on Nov 28, 2012
The machine makes some clicking noises when you try to start it and then says
Hello Al White - Typically error code ER indicates a membrane switch failure. Meaning that the main control board has detected a stuck key or key pressed for more than one minute. This will need to be checked and a repair performed by a technician since they must do the following: check connection from keypad to main control board, if correct the keypad will need replacing. If error still exists then tech will need to replace main control board.
10/11/2012 2:48:45 PM • Frigidaire... • Answered on Oct 11, 2012
Frigidaire FGHD2433KF starts when closing the door without pushing the on button
Hi Charles - From what you have described it sounds like there is a miscommunication with the control board/panel and you will need to contact a professional to diagnose it for repairs.
9/25/2012 5:42:27 PM • Frigidaire... • Answered on Sep 25, 2012
Frigidaire FGHD2433KF Builtin Dishwasher Logo
88 questions posted
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
drain already replaced drain pump
  • Dishwashers
