20 Most Recent
Whirlpool Gold GU2475XTV Builtin Dishwasher Questions & Answers
Normal wash light continually flashing
There is a trouble shooting document behind the kick panel at the bottom of the machine. Follow the steps to determine which component is at fault. It may be corrosion in the low voltage connector.
My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
My dishwasher is making noise and does'nt work
Jimmy:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address,
[email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Doesn't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems -
Waterwill not drain out
heatman101
Rust on metal bar of utensil container
Try sanding the rough rust off and touching it up with some nail polish. And make sure that all SHARP items are washed by hand so they don't slice through the protective covering.
Dishwasher stopped midcycle and the
Some dishwashers work the wire nuts loose in the connection box. Especially those that
are wired to aluminum wiring (these require the purple "IDEAL" brand wire nuts).
Make sure to secure power to unit before servicing.
Quit mid cycle - no
There may be a thermal fuse in the rear of the machine. If the door switch is faulty (which is common) then the machine won't do anything either. You can test the power from the power inverter to the control board with an ohmmeter to see if there is power being delivered.
