20 Most Recent VinoTemp VT12TEDI Wine Cooler Questions & Answers
My Vinotemp VT-12TEDI Wine
Replace the controller board. Only about $48 on eBay.
1/21/2015 3:49:28 PM • VinoTemp... • Answered on Jan 21, 2015
2answers
Our VT-12TED 12 bottle wine
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
10/5/2011 2:55:44 AM • VinoTemp... • Answered on Oct 05, 2011
I have a vinotemp VT-12TEDi
The thermostat may be bad. Test it with multimeter set in "ohm" to confirm that is defective before replacing.
12/12/2010 5:44:18 AM • VinoTemp... • Answered on Dec 12, 2010
0answers
0answers
How can I ensure the quality of a sofa when ordering online in the UK?
Your budget determines how much quality the sofa has
4/18/2024 10:12:05 AM • Furniture • Answered on Apr 18, 2024
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
  1. Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
  2. Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
  3. Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
  4. Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM • Furniture • Answered on Apr 17, 2024
Colorado metal 4 seater dining set with parasol assembly instructions please?
Question edited to remove Funky-Dash-Use- :>D Lots of pretty pictures, but no instructions. If it is new, reach out to the store or the online seller. It looks pretty easy by looking at the pictures and zooming in on the B&Q website. Lay all the parts out. https://www.google.com/search?q=Colorado+metal+4+seater+dining+set+with+parasol+assembly+instructions ..
4/14/2024 5:11:05 PM • Furniture • Answered on Apr 14, 2024
Brand new Koolatron 8 bottle wine cellar displays only in C degrees. Can't change to temp F. The button for C/F is the same as the light button. Light on/off works....
Touch the button to turn the light on, press and hold to 4 seconds. display from Celcius to Fahrenheit. Touch once to turn the interior light on or off. To switch between Celcius and Fahrenheit, hold button for 4 seconds.
DELUXE WINE CELLAR
4/6/2024 10:53:12 PM • Furniture • Answered on Apr 06, 2024
PC wining light indicates problem
Is this Wong Chan with his Sony Vaio question? Makes no sense 'wining'? 'whining' light, 'winning' light, still no sense. Posted to 'Furniture' category? All questions need 'make model (what it is)' first 3 words. https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+owner+manual Warning Lights? https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+wining+light+indicates+problem ..
4/6/2024 7:08:37 PM • Furniture • Answered on Apr 06, 2024
Getaway Elite Massage Chair. The wire that makes the chair move out is unplugged can't find where it plugs in?
Question edited for clarity. Back right hand side. Page 8 of the manual
RMS-10
Abt https://content.abt.com > documents > RMS10_om PDF Robotic MassageĀ® Chair ... The warranty applies only to the massage chair; accessories or enhancements are not covered. ... Get-A-Way "Elite" allows you to select ... 12 pages
4/4/2024 8:23:36 PM • Furniture • Answered on Apr 04, 2024
Where can I get a replacement door seal for my CDA Wine cooler model FWC602SS.
Check out the link. CDA sell spares direct, plus other vendors. You can also make your own. https://www.google.com/search?q=replacement+door+seal+for+my+CDA+Wine+cooler+model+FWC602SS ..
3/28/2024 5:55:14 AM • Furniture • Answered on Mar 28, 2024
Is cotton mattress good for back?
Yes it is. It is a natural material, breathes naturally and is capable of being kept clean.
3/27/2024 2:27:20 PM • Furniture • Answered on Mar 27, 2024
What is the best wine cooler in the market?
The NewAir AW-210ED is by far the most successful wine cooler there is making the best wine cooler overall for the price. The only downfall is that this specific model doesn't have the highest capacity for the price.
3/27/2024 2:23:42 PM • Furniture • Answered on Mar 27, 2024
Which brand provides the best wine coolers?
I don't know but if I needed to find out I would look first at the brands used by commercial establishments that buy for long life and reliability. While it is fashionable for wine to be overcooled, my father's words often come back to me, "if a drink has to be chilled to taste good, it is poor quality". White wines and pale beers are traditionally kept in a cellar. Cellar temperatures are between 45 and 54 F; comparatively mild temperatures that for most of the year in the temperate regions no refrigeration is needed...
3/27/2024 2:20:04 PM • Furniture • Answered on Mar 27, 2024
Can I use red wine in place of cooking sherry?
Yes it will work just as well. Mike My grandson is a Chef, his answer.
3/27/2024 2:14:47 PM • Furniture • Answered on Mar 27, 2024
How long can you keeo sherry cooking wine?
Though sherry tends not to spoil in the traditional sense, this fortified wine actually does have a shelf life. Most types of sherry can be kept unopened for up to three years, however Pale Cream sherries have a shelf life of two years, and Fino and Manzanillo sherries have a shelf life of no more than 18 months.
3/27/2024 2:13:44 PM • Furniture • Answered on Mar 27, 2024
What does an E4 message mean on Frigidaire Electrolux Wine Cooler Model FGIP2468. I have tried unplugging for a few hours to no avail
According to my notes, it is a failure of the defrosting sensor.Probably best to call a refrigeration engineer.
3/26/2024 8:16:28 AM • Furniture • Answered on Mar 26, 2024
VinoTemp VT12TEDI Wine Cooler Logo
8 questions posted
Top VinoTemp Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
View Most Popular
VinoTemp Furniture
  • VinoTemp Furniture
Most Popular Question
our vt 12ted 12 bottle wine
  • Furniture
