20 Most Recent Korg Pa800 61-Key Pro Arranger w/Spkrs Questions & Answers
Go to Alba's wed site and look for downloads where you should find operating instuctions.
Audio Players &... | Answered 8 hours ago
If you are a good handyman you can do the following: (1) Go to a hardware store and buy a cheat DVM (digital voltmeter). Go to the other bulb and measure the voltage and write down on paper. Then CAREFULLY remove the bulb and place it where the other one burnt out twice. Measure the voltage the same way. If the two voltages are identical, then it was simply a coincidence, take the burnt bulb and go to the Electronic Parts Store and buy two bulbs (the reason for two is that the other one remaining will also go not before too long). If the voltage is ghigher than the previous reading, take it to the attention of the manufacturer. There is a design error by their engineers and they need to fix it. They most likely will send you a new unit and ask to return the old one, so they can evaluate it. Now when we are talking about volts, we talk about tenths of volts difference. This scheme will also work with LEDs, but the bulb with the lower voltage is the one at fault. CONSTANTIN
Audio Players &... | Answered 11 hours ago
Sorry i couldnt find it .
However i found a review that should cover all speaker functions . Below is the link
https://youtu.be/urb8Ai6yOP0
Audio Players &... | Answered 20 hours ago
Hello Kristine, indicate brand, model and type of equipment that you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Kristine, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Can anyone please help me.. may megavision ako, I connect it to my sony tv and sony home theatet system pero pag kumanta ako may delays sa voice ko.ano po pwede ko gawin para mawala yun please helppp...
Audio Players &... | Answered Yesterday
if it have headphone jack,,,connect head phone if it work ...check its speaker.....if speaker is OK then replace its audio IC....if you are electronics knowing person...
Korg Pa800 61-Key Pro Arranger w/Spkrs Logo
1 questions posted
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Korg Audio Players & Recorders
Most Popular Question
burnt ic chip korg microkorg pcb
  • Audio Players & Recorders
