20 Most Recent Microsoft Access 2003 for PC Questions & Answers
1. open access. 2. From file menu select open => select the location of .mdb file and while selecting open option you notice a small triangle. Click that triangle and select open exclusive. after file opening go to database tools and select set database password. give the password and save it. Thats the procedure
Microsoft Access... | Answered on Apr 10, 2019
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Microsoft Access... | Answered on May 04, 2017
Have you considered just buying something like the "Haynes Repair Manuals" on CD ROM or another similar program? there are plenty good ones out there already, myself I usually prefer Haynes.
Microsoft Access... | Answered on Sep 24, 2012
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
Microsoft Access... | Answered on Oct 16, 2010
I would need more info to be certain, but it sounds like you need to
a. remove the link
b. in a server domain, remove the permissions of those improperly accessing
or
c. password protect it
Hope this helps.
Microsoft Access... | Answered on Apr 03, 2010
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Microsoft Access... | Answered on Oct 16, 2009
You cam visit this link to see the detailed functions available in Ms Access 2003. See if this has the function you want...:)
http://office.microsoft.com/en-us/access/HP011359591033.aspx
All the best.
Regards,
Shrey
Microsoft Access... | Answered on Oct 13, 2009
Hey everyone, I was able to fix my problem using the following:
filnam = Me![Text2]
Set objFile = CreateObject("Scripting.FileSystemObject")
Set objText = objFile.OpenTextFile(filnam)
Set rs = CurrentDb.OpenRecordset("FlatFileImport")
once = False
If Not IsNull(Me.Text2) Then filnam = Me.Text2
Open filnam For Binary As #1
Do While Not objText.AtEndOfStream
strTextLine = objText.Readline
Data = Split(strTextLine, ",")
If once Then
rs.AddNew
rs.Fields(1) = Data(0) 'Site ID
rs.Fields(2) = Data(1) 'Client ID
rs.Fields(3) = Data(2) 'Client Name
rs.Fields(4) = Data(3) 'DDA Account
rs.Fields(5) = Data(4) 'Process Date
rs.Fields(6) = Data(5) 'Good Checks Singles
rs.Fields(7) = Data(6) 'Good Checks Stubs
rs.Fields(8) = Data(7) 'Good Checks Partial
rs.Fields(9) = Data(8) 'Good Stubs Partial
rs.Fields(10) = Data(9) 'Good Checks Multi
rs.Fields(11) = Data(10) 'Good Stubs Multi
rs.Fields(12) = Data(11) 'Check Only Checks
rs.Fields(13) = Data(12) 'Check Only Stubs
rs.Fields(14) = Data(13) 'Check And List Stubs
rs.Fields(15) = Data(14) 'Check And List Checks
rs.Fields(16) = Data(15) 'Suspense Checks
rs.Fields(17) = Data(16) 'Suspense Stubs
rs.Fields(18) = Data(17) 'Correspondence
rs.Fields(19) = Data(18) 'Envelopes
rs.Fields(20) = Data(19) 'Express Mail
rs.Fields(21) = Data(20) 'Lookup Stubs
rs.Fields(22) = Data(21) 'Online Lookups
rs.Fields(23) = Data(22) 'Stubs Only
rs.Fields(24) = Data(23) 'StopFile Hits
rs.Fields(25) = Data(24) 'SLC
rs.Fields(26) = Data(25) 'SL2
rs.Fields(27) = Data(26) 'MICR Scanline
rs.Fields(28) = Data(27) 'KeyStrokes Correspondence
rs.Fields(29) = Data(28) 'Keystrokes SLC
rs.Fields(30) = Data(29) 'Keystrokes SL2
rs.Fields(39) = Data(38) 'Exception Queue
rs.Fields(40) = Data(39) 'COA Queue
'IMAGE ARCHIVE ITEMS
rs.Fields(41) = Data(40) 'Image Archive Reports
rs.Fields(42) = Data(41) 'Image Archive Storage
'BATCHES PROCESSED
rs.Fields(43) = Data(42) 'Batches Processed
'ARC ITEMS
rs.Fields(44) = Data(43) 'Low Speed ARC Attempts
rs.Fields(45) = Data(44) 'High Speed ARC Attempts
rs.Fields(46) = Data(45) 'Low Speed ARC Converted
rs.Fields(47) = Data(46) 'High Speed ARC Converted
'ICL ITEMS
rs.Fields(48) = Data(47) 'ICL Attempts
rs.Fields(49) = Data(48) 'ICL Converted
rs.Fields(50) = Data(49) 'ICL Non-Conforming images
'RETURN ITEMS
rs.Fields(51) = Data(50) 'Auto Returns
rs.Fields(52) = Data(51) 'Returned Items
'POSITIVE POST (CDM) ITEMS
rs.Fields(53) = Data(52) 'Positive Post Checks
rs.Fields(54) = Data(53) 'Positive Post Stubs
'REMOTE PAYMENT CAPTURE ITEMS
rs.Fields(55) = Data(54) 'Remote Payment Single Checks
rs.Fields(56) = Data(55) 'Remote Payment Single Stubs
rs.Fields(57) = Data(56) 'Remote Payment Multi Checks
rs.Fields(58) = Data(57) 'Remote Payment Multi Stubs
rs.Fields(59) = Data(58) 'Remote Payment Check Only Checks
rs.Fields(60) = Data(59) 'Remote Payment Check Only Stubs
rs.Fields(61) = Data(60) 'Remote Payment Check & List Checks
rs.Fields(62) = Data(61) 'Remote Payment Check & List Stubs
'DOLLAR DEPOSTIED & PP CORRO REJECT ITEMS
rs.Fields(71) = Data(70) 'Dollars Deposited
rs.Fields(72) = Data(71) 'PP Corro Rejects
rs.Update
End If
once = True
MyLine = ""
MyLine = MyLine & ch
MyLocation = Loc(1)
Loop
MsgBox " File has been successfully imported! "
Close #1 ' Close file.
rs.Close
'close and erase the file from memory
objText.Close
Set objText = Nothing
Set rs = Nothing
Microsoft Access... | Answered on Sep 09, 2009
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Microsoft Access... | Answered on Aug 12, 2009
In the Design view for your form element (eg textbox), go to the Data Tab. Look at the options for:
Input Mask, Validation Rule and Validation Text. You can use any combination of these to force a user to enter something in the field. If you just want to check that the contents of the element has a non-zero length, then you can write an event (Events tab) to check the length of the values entered. If 0, then throw a message box and re-focus the cursor on the textbox.
Microsoft Access... | Answered on May 19, 2009
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Microsoft Access... | Answered on May 01, 2009
Unfortunately, there is no such thing as a free MS Access. If you need MS Access, you will need to purchase it either on line or in an office supplies store.
As a free alternative, you can download OpenOffice from www.openoffice.org. All Open Office applications are completely compatible with all MS Office applications.
Thanks for using the FixYa forums!
Microsoft Access... | Answered on Mar 30, 2009
You have to go into the design view of the form. On the field(s) that this is happening to, right click and select properties. The select the Event tab. Go down the list and look for the "On Mouse Move" perperty. See if there is an Event Procedure in the block to the left. If there is, that is most likely what is causing this to happen. The procedure is probably written to perform this action.
Microsoft Access... | Answered on Mar 27, 2009
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
Microsoft Access... | Answered on Mar 24, 2009
Hi Rakesh,
in MS Access 2003/2007, the first record is always highlighted in table as well form's text controls when they connected to a database. In a query cursor is always at last record.
In flex-grid control you can set its properties to get cursor on a particular records.
I think your problem is solved.
Please contact if not.
Zulfikar Ali
Microsoft Access... | Answered on Mar 07, 2009
First one apply short guide, second make use of http://www.mdb.openfiletool.com/ MDB Open File Tool
· Launch the Microsoft Access application, but do not try to open the corrupted MDB file.· Go to "Tools" in the top menu bar, expand the "Database Utilities" submenu and select the "Compact and Repair Database" option if you are using Access 2002 or 2003. If you are using Access 2007 or 2010, you can find the "Compact and Repair Database" option by clicking the Microsoft Office button and going to the "Manage" menu.· Highlight the MDB file that you want to restore and click the "Compact" button.· Enter a name for a new database file, which will contain the restored data from the damaged MDB file.· Navigate to the location on your hard drive where you want to save the restored version of the file.· Click the "Save" button. Access will now compact and repair the MDB file and save a restored version in the location you selected.
Microsoft Access... | Answered on Apr 15, 2019
Microsoft Access 2003 for PC Logo
Popular Tags
21 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Access Microsoft
  • Access Microsoft
Most Popular Question
access database 2003 problem copy
  • Computers & Internet
