20 Most Recent Microsoft OFFICE 2003 BASIC OEM ENGLISH MS (S550039701) Questions & Answers
3answers
Converting doc to pdf with link reference
Try to download save as PDF converter for office application.
2/2/2021 11:44:30 AM • Microsoft OFFICE... • Answered on Feb 02, 2021
2answers
VBA and macros
SLA consultants in India. The training program is intelligently designed by industry experts to provide hands on experience and in-depth knowledge to the participant regarding MA Access database and Visual Basic for application programming. The training will use real time practical sessions and live projects and assignments to offer you a better understanding of both the tools. https://www.slaconsultantsindia.com/vba-macros-programming.aspx
6/12/2019 9:44:04 AM • Microsoft OFFICE... • Answered on Jun 12, 2019
2answers
HOW CAN I MATCH THE TWO WORKSHEET FOR RECONCILIATION
Try this:
1. Find the copy of the workbook on which you will merge the changes. In Excel, go to "File > Open" and find the file.
3. Click "Tools > Compare" and "Merge Workbooks." 4. Look for the files you want to merge and add them into the current file. 5. Click “OK” to merge the files. This is your master copy of this workbook. 6. Save the file.
11/14/2018 8:41:17 AM • Microsoft OFFICE... • Answered on Nov 14, 2018
2answers
Unable to Install MS Office on Laptop
You won't find the download link as office 2003 is not supported anymore. (had same issue as I owned office 2003 had to go to office 365) I am not sure if later versions of office would run with office xp ? suggest trying open office https://www.openoffice.org/download/ and see if it works on your windows xp.
1/18/2018 12:13:29 AM • Microsoft OFFICE... • Answered on Jan 18, 2018
4answers
My MS Office 2003 will not install on my Windows 10 OS. I have the discs and product key. Is there a patch that will allow me to install this program on my laptop? My laptop is about 3 years old
the problem may be compatibility as win 10 has it's own office system called office 356 which is superior to ms office 2003
6/3/2016 2:32:25 PM • Microsoft OFFICE... • Answered on Jun 03, 2016
What word is a modification of a verb,adjective,or
"in the room" is an adverbial phrase for the subject "Farrah's purse" and verb "was".
9/24/2013 2:47:38 AM • Microsoft OFFICE... • Answered on Sep 24, 2013
ALL MY EXCEL FILE HAS BEEN CORRUPTED PLZ GIVE
You may try xls repair worksheets, fonts, formulas, cells, columns, rows and etc.
9/25/2012 11:45:01 AM • Microsoft OFFICE... • Answered on Sep 25, 2012
2answers
Access database was copied now no tables in dropdown list
Your version of Access may require slightly different menus and clicks than mine, but the procedure is straightforward and should be very similar to what you will need to do. Read the whole post first!
Make sure you have permission to modify the database, then go to the form (I assume the drop-down table is in a form) and go to design view.
In design view, click once on the dropdown box you are having a problem with, and a properties screen with several tabs should pop up; click on the data tab, and look at 'data source'. In the list look for 'row source type' to see if the source of your data is a) a table or a query, b) a value list or c) a field list. Most dropdown boxes use either a value list or data from another table or a query (based on a table).
Check the source of data by going down to the next line in the list titled 'Row Source' (this is the list on the data tab that popped up when you clicked on the dropdown box in design view).
If the source is a table/query type you should see some code in the Row Source box like "SELECT....". Without changing anything, click once immediately to the right of the box, and whatever source the rows are coming from should pop up--if a query, for instance, it will pop up the underlying query in design view.
You should be able to troubleshoot the underlying query to see why no data is given in the dropdown box.
Another point where underlying query or table is used: If the table was based on a query that pulls data from the records in the current database, the drop down list will be blank until new records are added so the query has something to list.
And if the source is a 'value list', the values should be included in the row source box below, separated by semicolons. If not you simply need to add them in.
If your source is a field list, go back to whomever copied the database and tell them you need help with the copy they gave you...
5/21/2012 6:12:29 PM • Microsoft OFFICE... • Answered on May 21, 2012
Missing sku011.cab
Do you still have the install CD? If so you can copy this file from the CD. It's probably named something like sku011.ca_. You may have to extract it to the location. Do a little Google searching on Extracting a CAB file and you'll probably find the result you're looking for.
12/17/2011 1:15:46 PM • Microsoft OFFICE... • Answered on Dec 17, 2011
How do I get ride of all WordPad files
WordPad comes as part of Windows, it doesn't really have any files (documents) you can however associate file types to it. .txt and .rft If you want these types of files to open in say word. Right click any .txt file and any .rft file, select Open With, "Choose Default Program", Select Word and make sure "Always use the selected program" is check" and those file types will now always open in Word. If this is not what your looking for please comment back and elaborate on your issue you are having.Thanks.
11/28/2011 7:30:34 PM • Microsoft OFFICE... • Answered on Nov 28, 2011
How can download a free MS office software
you could go to major geeks to download open office which uses similar applications to Microsoft office 2007 and has many of the options of office 2007 bonus its FREE
http://www.majorgeeks.com/OpenOffice.org_For_Windows_d3461.html
dont forget to vote
hope this helps
2/4/2011 2:19:07 AM • Microsoft OFFICE... • Answered on Feb 04, 2011
I want to download ms office 2003 please give me
Did you know Microsoft offers a free online version of Microsoft Office? You don't have to pay for Office unless you want additional features. The free version from Microsoft is here:
http://www.skydrive.com/
Facebook has free online Office applications at:
http://www.docs.com/
1/11/2011 10:07:06 AM • Microsoft OFFICE... • Answered on Jan 11, 2011
Margin too wide
File menu, Page Setup, Margins Tab, use arrows to adjust margin value, or enter numbers directly. Inches and tenths.. Example, Normal standard margin is 1.25" You could enter 0.75 (3/4ths ")
1/2/2011 11:40:30 PM • Microsoft OFFICE... • Answered on Jan 02, 2011
HAPPY NEW YEAR ...WHEN I
happay new year same to u brother plz update ur office
1/1/2011 5:32:09 PM • Microsoft OFFICE... • Answered on Jan 01, 2011
How to install ms office 2003 F WE DON'T HAVE THE
There is no way to do it.Maybe at a torrent site but you will need the keys to install it.Or make a copy of your friends MSO 2003.
12/12/2010 7:01:53 AM • Microsoft OFFICE... • Answered on Dec 12, 2010
I want office2003
check here
11/29/2010 5:17:18 AM • Microsoft OFFICE... • Answered on Nov 29, 2010
What is the use of the ms word?
Hi Good day!!
What can you use MSWORD for?
Many organisations now use computers to produce and organise written material, correspondence, membership lists and so on. This guide deals with the most common programme, MSWORD, that is used on most computers. It is written for people who have not used the programme before and has very basic information about the keyboard and MSWORD. If you have taught yourself to use MSWORD, it may also be useful to you.
Your MSWORD programme is called a word-processing package. This means that it is useful for typing and storing letters, articles and anything that consists mainly of words. It is basically a fancy typewriter with a built in filing-system.
The more you use your computer the more you will learn about what it can do. This guide contains a few basic things to help you get started.
If you have not used a computer much, print the next section out and look at your keyboard and MSWORD programme with it. Try to do everything as you read it.
10/26/2010 5:34:41 AM • Microsoft OFFICE... • Answered on Oct 26, 2010
Its for calculating the stak ranking
=IF(D1>=85,"5",IF(AND(D1>=75,D1=65,D1=55,D1=45,D1
You should use above formula. It will be useful for you.
10/14/2010 3:58:00 PM • Microsoft OFFICE... • Answered on Oct 14, 2010
Computers & Internet Logo
65 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Office Microsoft
  • Office Microsoft
Most Popular Question
margin wide
  • Computers & Internet
