20 Most Recent Microsoft Entourage For Mac for Mac Questions & Answers
4answers
Entourage Error 3259
This may be due to the means of authentication being used -- by the STMP server you are sending to and/or the authentication options selected in your Entourage setup. Mail servers commonly establish restrictions based on authentication to restrict who can send mail through them as a means of preventing spam.
Cable companies for example, and possibly your campus network, often restrict the sending of Mail to those computers that have a local connection to their network based on the IP address they are using -- i.e. where you plugged in or which wireless adapter you are connected to. Alternatively, many others require your mail client to present your user name and password to authenticate... or possibly to authenticate only in those cases when you are not connected locally.
So... to get an iron clad answer, you need to find out from the Mail server administrators what type of authentication is required. This information is often listed on "help" web pages describing how to set up your mail client... or call them if you can. Alternatively, check your Entourage setup to see how it is contacting the server for outgoing mail. Try changing the authentication method to use Password authentication if it is not already. Ultimately, the mail administrator for your Mail server is likely your best help resource.
Hope this helps.
1/23/2017 12:11:55 PM • Microsoft... • Answered on Jan 23, 2017
2answers
Entourage Hot sync failure with Palm (error = #-1)
1. Right click Red/Blue synch icon in lower right corner
2. Select custom
3. See how many items are in two way synch
1/9/2016 7:58:21 PM • Microsoft... • Answered on Jan 09, 2016
How do I delete incoming mail in Entourage
Hi, First try logging into your Web based email server, (ie.gmail.com, yahoomail.com). then delete those mails from inbox then try logging in using your entourage.
9/30/2014 5:29:02 PM • Microsoft... • Answered on Sep 30, 2014
How do a delete an incoming mail which seems to be stuck and blocking rest of incoming mail
I suggest logging directly into the webmail interface through your browser. Most Internet Service Providers (ISPs) have a web based interface (much like Gmaile and Hotmail/MSN) where you can login (using your email address and account password) and access your email that way. You can simply review the messages in your Inbox and delete anything you do not want to download.
9/18/2014 9:25:19 PM • Microsoft... • Answered on Sep 18, 2014
2answers
Import Mail to Entourage 2008 I am thinking of
A normal search on the browser you use can give you many answers for your problem, here's a google search:- Mac Outlook 2011 Import Or there are many applications available for these kind of problems now-a-days, the one I have used and have been successful every time is Apple mail Export to Outlook 2011. I hope this helps you Thank you
10/19/2013 1:17:19 AM • Microsoft... • Answered on Oct 19, 2013
2answers
Copy Outlook files to Entourage 2008 Hello, I
Making IMAP Account Well creating an imap account can help you. You have to simply make imap accounts on both the email clients you use and then you can upload you emails from outlook and then download on the other hand in apple mail. Other alternative You can also use the software approach to solve your problem. Various softwares/applications/third party tools are available online. One I am aware of is Pst Converter pro. Hope this helps thank you
10/14/2013 6:52:42 PM • Microsoft... • Answered on Oct 14, 2013
0answers
Can't retrieve email. Getting "[SYS/TEMP] problem retrieving messages"
I have the same problem at about the same date. I had an answer in macacos web, look here. It worked, but in my case the problem returned.You can try: http://www.macacos.com.uy/foros/viewtopic.php?id=16183
2/5/2013 1:21:39 PM • Microsoft... • Answered on Feb 05, 2013
2answers
Unable to receive mail in Entourage from POP server.
Not really sure what is wrong but would suggest that you check your account setup under tools/Accounts and see if the setting for advanced settings for receive is set to "This POP service requires a secure connection" is checked or not. It depends on what your ISP requires
8/14/2012 7:32:19 AM • Microsoft... • Answered on Aug 14, 2012
As of today. I'll emails with attachment I'm
Hi,Let me guess, the emails are coming from a Windows PC not a Mac. There's no problem with your Entourage. The problem is the Windows PC sending emails to you.Based on my research, This issue usually happens when a Windows PC sending emails with attachment to a Mac is running Windows Vista and using Goggle Chrome as their default browser.Hope this helps.Cheers!
12/2/2011 5:32:30 AM • Microsoft... • Answered on Dec 02, 2011
When i log onto entourage, it has me put in
Hi,Try to login to your Webmail and see if you can login. when I say Webmail, for example you have a hotmail account, try to login to www.hotmail.com by using Safari or any internet browser.If you can't login to webmail, that means you're enterring the wrong password. But if you can login, most likely you have a corrupted account profile. Try recreating your account in Entourage.Hope this helps.Cheers!
12/2/2011 5:21:28 AM • Microsoft... • Answered on Dec 02, 2011
Entourage crashes when I try to delete "sent messages"
Hi,If you suspect that something is corrupted at the end of the message, you might need to recreate the messsage. if you're sending a message with an attachment, the attachment might be too large. Try sending the message by deleting the images on your signature.Hope this helps!Cheer!
12/2/2011 5:16:35 AM • Microsoft... • Answered on Dec 02, 2011
Entourage chrashes when I delete sent messages
Hi,If you already rebuilt the Database and still crashing, that means that your Database(Main Identity) is already corrupted and you need to start a fresh database.Try deleting the messages in your Webmail if you're using IMAP account. Most likely, that message that was stucked in your deleted items folder is causing the issue.If you have TimeMachine enabled, restore to the date when Entouarge last worked.
12/2/2011 5:11:02 AM • Microsoft... • Answered on Dec 02, 2011
When I write an Email and want to address the
Hi,If you want to remove recent email address used in Entourage, follow the steps below.1. Open Entourage2. Click the word "Entourage" next to the Apple logo(top left) then choose Preferences3. Click on "Compose" on the pop-up window4) Click on "Clear List" button on Recent Adresses.Let me know if its successfull or not.Charvin
12/2/2011 5:06:46 AM • Microsoft... • Answered on Dec 02, 2011
Entourage will not open it
Launch Microsoft Database Utility. Type Database in Spotlight(Magnifying Glass in upeer right hand of screen) then choose Microsoft Databse utility. CLick main identity then Tick Rebuild Database. You need to quit all Microsoft Office Mac Applciations also before opening Databse utility. After rebuilding, click done and then quit databse utility. Then open Entourage. Hope this helps!
4/28/2011 7:35:54 AM • Microsoft... • Answered on Apr 28, 2011
2answers
I am no longer able
Do you get an error messages within Entourage when receiving? First thing I would check would be my account settings. Does your receiving email server require SSL or any other special settings?
3/11/2011 5:22:14 PM • Microsoft... • Answered on Mar 11, 2011
MS Entourage is very slow - the spinning wheel of death
Michael, if you have the option can you use IMAP instead of POP3 for your email server settings? If your email service provides IMAP you might try it as it may appear to work faster than POP3.
2/18/2011 2:37:19 AM • Microsoft... • Answered on Feb 18, 2011
0answers
Computers & Internet Logo
33 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
import mail entourage 2008 am thinking
  • Computers & Internet
