20 Most Recent Pioneer PRO-99 TV Questions & Answers
When turning on the TV all I get is a click sound, the red light remains red and no picture or sound.
Sounds like the tv is on standby, and needs to be switched on after via the remote control.
8/25/2013 7:14:23 PM • Pioneer PRO-99... • Answered on Aug 25, 2013
Pioneer pro 99 convergence ic's
What is the model #?
11/28/2012 2:11:11 AM • Pioneer PRO-99... • Answered on Nov 28, 2012
No picture but sound
The flyback transformer to your TV has the fault. Contact any expereinced service technician to get it repaired. Picture tube faulure is very very rare.
5/1/2012 2:51:37 PM • Pioneer PRO-99... • Answered on May 01, 2012
Will not power up has constant on off flicker ,
Hi Eric,First of all, thank you for contacting Fixya.com regarding on your TV problem.I've suspected a convergence chips failure not the power supply board issue in this kind of symptoms. To confirm it, locate the convergence board inside the set, it has a Sanyo convergence chip STK392-110 that are mounted on the large heat sink. This board has a LED (light emitting diode) that will light up once the board gone to malfunction. Turn on the unit and then check if the LED will lit after the shuts down. If yes, then I would advice you to replaced both convergence Chips and check the resistance of the resistors in line with the +25V and -20V supply of the chips.Let me know if the LED at the convergence board does not lit to continue our diagnosis... Check also the LED at the power supply board and on the deflection board(this is where the flyback transformer is located)Have a nice day!Goodluck and take care!Kind Regards,Jdvillanueva
12/4/2011 12:52:07 PM • Pioneer PRO-99... • Answered on Dec 04, 2011
The tv is not turning
hi my friend double check ur power chord or ur outlet... if doesn't work go to nearest tV repair shop God Bless...
5/28/2011 3:22:52 AM • Pioneer PRO-99... • Answered on May 28, 2011
4answers
Problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
5/7/2010 4:03:10 PM • Pioneer PRO-99... • Answered on May 07, 2010
TV will not power on. Never when using the remote,
Ur video ic converter board it dead.
Need a new board.
8/17/2009 3:32:58 AM • Pioneer PRO-99... • Answered on Aug 17, 2009
Can you tell me the resolution for this model. I'm
resolution is 1000
7/30/2009 9:35:08 PM • Pioneer PRO-99... • Answered on Jul 30, 2009
2answers
X volt regulator
1) Unplug wire harnesses = pull chassis ( requires 2 chassis bolt
removal)
2) Dis-mount Convergence / power supply board = the one with
large heatsink
3) Locate 5 volt regulators mounted to heatsink
4) Remove old solder from pins of all four regulators =
Re-solder + solder any / all bad conncts on board....
5) Replace bad 4 amp fuse hidden in power supply area...
6) Reassemble
4/19/2009 11:10:53 PM • Pioneer PRO-99... • Answered on Apr 19, 2009
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
4/18/2009 2:40:36 AM • Pioneer PRO-99... • Answered on Apr 18, 2009
2answers
Blue tint on rear projection tv
hello. it might be as simple as a magnetic field near your tv.if you have any large metal things or speakers on top or next to yourtv try moving them about a foot away from the tv and see if that helps
3/15/2009 4:05:09 AM • Pioneer PRO-99... • Answered on Mar 15, 2009
My TV has sound but No picture
Requires chassis pull by a technician and then solder any/all
bad connects, esp. horizontal circuitry......................T.
3/1/2009 10:22:52 AM • Pioneer PRO-99... • Answered on Mar 01, 2009
Wont power on
See Speargunner Oct.26,2007.........................T.
5/4/2008 4:48:02 AM • Pioneer PRO-99... • Answered on May 04, 2008
CUT OFF TO STANBY
See Speargunner Oct.26,2007.................................T.
12/24/2007 3:31:05 AM • Pioneer PRO-99... • Answered on Dec 24, 2007
Samsung rear projection tv
WE always need the model #..............................T.
11/15/2007 5:02:53 PM • Pioneer PRO-99... • Answered on Nov 15, 2007
Pro 99
Sounds like convergence outputs. Possibly some biasing resistors.
7/7/2007 1:12:59 AM • Pioneer PRO-99... • Answered on Jul 07, 2007
Televison & Video Logo
26 questions posted
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
x volt regulator
  • Televison & Video
