20 Most Recent
KitchenAid Salad and Fruit Spinner - White - Kitchen Utensils Questions & Answers
How do I remove the plunger for washing?
The plunger on mine cannot be removed. I just checked it to make sure. If you remove it, you have broken the unit. Just rinse with water. The plunger should not get dirty of used properly. A rinse under running water is enough.
Sink pop up waste won't close
When you pull out the stopper is it completely intact? there should be a hole at the bottom of the stopper were a rod goes through. That moves on an axis pulling and pushing the stopper up and down as you pull and push the lever. You have to make sure you get the rod in that hole for the pop-up to work. You can google pop up assembly and look for an diagram. good luck
Kitchenaid kadette 250 1/2 hp won't turn on.
Try turning off the circuit breaker and turning it back on, pushing the reset button firmly on the bottom of the disposer, and checking to make sure it's not jammed and rotates freely. If it is jammed you can put a disposer wrench or allen wrench in the hole in the bottom and rotate the shaft to free it. There might already be a wrench under your sink for that.
KA KAdette 250 - I hit the switch the other day
12 years is middle aged for an appliance, but the problem is probably one of the garbage disposal big three: a tripped circuit breaker, a tripped reset button, or a jammed disposer. With the breaker turned off, make sure the disposer's shaft rotates freely. On most disposers there's a hole in the bottom middle where you can insert an allen wrench that you're probably find under the sink and rotate the shaft manually to free jams. But, for the love of God, only do this with the breaker turned off and make sure you remove the wrench (or broom handle if you have to go from the top) from the disposer before turning it on. Make sure the reset is pushed down until it clicks if it's tripped, and, since circuit breakers get old and stick, you'll have to turn the breaker all the way off and back on to make sure it's not tripped. If the disposer hums but doesn't turn when you turn it on, check to see if it's jammed. If it turns freely but hums and doesn't start then the starter circuit on the motor is bad. If the breaker and reset button are ok and it doesn't even hum when you turn it on, you'd want to check the disposer to make sure it's getting power. You can find a little electrical reader at walmart for $5 that works like a geiger counter and will beep when it gets close to something that's receiving power. The switch may be worn out, but really the disposer's motor failing is probably the least likely thing. But please get a qualified electrician out there if you don't know what you're doing. There's a reason that it requires a license.
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
