20 Most Recent
RARLAB WinRAR Questions & Answers
My important documents with no access
Try this guide below or may recovery rar via
https://rar.recoverytoolbox.com/
Open the file in WinRAR (download from internet if you don't have one).
Press your right mouse-button.
Click on "Repair archive", or press Alt+R.
Click on Browse button and select a folder where you want to keep the repaired archive.
There will be two options ("Treat the corrupt archive as RAR" and "Treat the corrupt archive as ZIP").
Select any one of your choice (or see which one will work) and click on OK button.
Go to the folder where you have kept the repaired archive and open it (Repaired archive will be named as rebuilt.*.rar or rebuilt.*.zip, where * is the name of original archive).
WinRar Unexpected end of archive.
There are few reasons for getting
unexpected end of archive RARerror; you usually encounter this error when you start a downloading process and after downloading few GBs (gigabytes) or MBs (megabytes), it stops and displays a message as download complete.
Given below are the steps which might help you in recovering some files from your corrupted RAR archive:
·Download RAR Fix Toolbox software and install the software to your computer desktop/laptop
https://www.fixtoolbox.com/rarfix.html
·Launch the repair application and stick to the procedure
·Hit the "Browse" button to choose the RAR file which is to be repaired
·Initialize the repair process by clicking on "Repair" button
·The program starts the repair process
·Monitor the repair process via progress bar
·After finishing the repair process, the tool displays all the files and folders from the RAR file
·Click on "Next" button
·Finally, save the repaired files to your desired destination location by making use of "Save" option'
WinRar. CRC is wrong
Follow these instructions:1 Open the WinRARAPPLICATION. Click on "File" and then "Open Archive" and browse to the damaged .RAR file.
2 Press "Alt" + "R" on your keyboard. This will bring up the WinRAR repair dialog screen.
3 Designate an easy-to-find location in the "Folder to put the repaired archive" box.
4 Check the box that says, "Treat the corrupt archive as RAR."
5 Press the "OK" button. Once it has finished repairing, a new archive will be built and placed in the location you designated.
also you can use RAR Fix Toolbox
Corrupt rar/winrar Archive
Maybe is uploading to the FTP site using ascii transfer type, once on the FTP connections, you should use binary type.
that is done with the command bin:
The following FTP Command will set the file transfer mode to BINARY (the binary mode transfers all eight bits per byte and must be used to transfer non-ASCII files). ) and display the information.
ftp> binary
200 Type set to I.
ftp
How to view corrupted rar?
RAR is the native format of WinRAR archiver. WinRAR tool is not only used to create RAR file but also used to repair corrupted RAR file or fix corruption from them. Whenever WinRAR fails to extract data from RAR archive, it means the archive is invalid or corrupted. You can repair the corrupted RAR archive by using the built-in repair feature of WinRAR application. All the required steps are shown below:
Solution #1
1) Open your WinRAR application.
2) Click on File tab and then click on Open archive. Or simply press Ctrl+O.
3) A new small window "Find archive" will be appeared.
4) Now locate your corrupt RAR file from the system directory and then click on Open.
5) Click on Tools tab and then click on Repair archive. Or simply press Ctrl+R.
6) Again a new small window "Repairing FileName.rar" will be appeared.
7) Now Browse the location where you want to save the new repaired archive.
8) The box "Treat the corrupt archive as RAR" is checked by default. But if it is not, then do check it.
9) Click on OK. The repairing process of selected archive will be started.
10) Once it is successfully completed click on Close.
Solution #2
RAR Viewer Tool -
http://www.rar.viewertool.com/
How to recover damaged ZIP files?
Try:
Recovery Toolbox for Zip is used to recover files from corrupted ZIP archives. The program scans the archive, detects the data structure and tries to recover as much information from the corrupted file as possible. Using several different recovery algorithms, the tool makes it possible to achieve the minimal loss of useful data stored in the corrupted archive. Also, it checks data integrity, which allows it to increase the quality of recovery.
For more information:
https://zip.recoverytoolbox.com/
Rar file recovery
i assume you are extracting the AVI by selecting ALL the rar files at the same time and hitting extract....you might be able to download the torrent file again and select to only download the one rar piece..
RAR archive is corrupted, can't extract.
You may need to buy A new Memory card Memory chip or what ever kind it takes. They are not to costly buy call the company that you bought it from and see if they have one for that model.
Good luck and hope this helps.
Wifi driver
Just visit this sitewww.driverguide.comYou will find any drivers that you need.
