20 Most Recent
Pioneer DV-F727 DVD Player Questions & Answers
Remote control problem pioneer dv-f727
A few thoughts.1. The remote was water/liquid damaged and the buttons no loger make contact with the silicon board to send a signal.2. Low battery??3. If you are using a universal remote, you may have found a code that only partially functions. Keep going through the codes until you find one that fully functions.Hope this helps!
My Pioneer DV-F727 multi-disc player
SInce the machine has a lot of linkages in the loading mechanism with mechanical drive gears and shafts controlled by MODE switches and optocouplers it is possible that there is a problem of FALSE detection within the transducers which make the loading motor to trigger so as to reset to park.
Now sometimes this is related to a speck of dirt on the optocouplers/sensors. Try and use a good air jet to clean the inside. Also if there is a faulty mode detect in the loadin circuit it can cause the MOTOR TO SHUNT resulting in the noise.
Finally it is best to OBSERVE after opening the mechanism to check for the source of noise and the cause seen visually which will be first hand information.
Could you advise please how to change the DVD
1. Make sure there is no disc in the
player's tray.
2. Press Setup on the remote control.
3. Move over to General using the arrow keys.
4. Select Basic.
5. Press Display, which should show the current region and firmware revision.
6. Press Condition/Memory, which should not change anything.
7. Press the number of the region you require.
8. Press Menu to store the region.
Let me k ow,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Music only disc won't play.
Laser eye is dirty,have problems.Tries websites like Amazon.com,Ebay.com to buy a DVD player cleaning kit,to play,to clean the laser eye.
My pioneer amp 820w blinking blue why?
The blue blinking light on your Pioneer amp could indicate a number of issues. One possible reason is that the amp is in "standby" mode, which means that it is not currently receiving any audio signals. Another possibility is that the amp is experiencing an error or malfunction.
To get a better understanding of the issue, I would recommend checking the user manual for your Pioneer amp. If you don't have the manual, you can try searching for it online using the model number of your amp. You can also try resetting the amp by unplugging it from the power source for a few minutes and then plugging it back in. If the problem persists, it may be time to take your amp to a professional for repair.
11/20/2023 8:53:25 PM •
Pioneer...
Answered
on Nov 20, 2023
