20 Most Recent Pioneer 1000 Watt 5.1 Surround Sound System System Questions & Answers
Why is 'No Disc' on the display screen when dvd is loaded?
Is it a DVD player? If not then it will not run any dvd
7/16/2014 5:32:57 PM • Pioneer 1000... • Answered on Jul 16, 2014
Disk compartment is came off the track and not
if your system is still covered by the warranty i would take it back to the shop to be repair d
10/2/2011 7:51:38 AM • Pioneer 1000... • Answered on Oct 02, 2011
Need manual for a pioneer home theater surround
Does the system have a model number? It matters if you want a manual.
You might find it at the manufacturer's support site, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
The remote...
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=XXD3175&brand_pn=PIONEER_XXD3175&mode=large&uuid=A13155241373361
Or search for it on the web using the product model number and 'remote'.
9/8/2011 11:28:00 PM • Pioneer 1000... • Answered on Sep 08, 2011
Rear speaker won't work and i can't get
check the rear spkr first using multitester
8/1/2011 2:23:53 AM • Pioneer 1000... • Answered on Aug 01, 2011
Hi .. need to connect
"Component" cable refers to the 3-wire hi-def video connection. It's irrelevant to audio.
Assuming you get all your TV programming through a cable box...
The TV wouldn't actually be a source of audio.
I would advise you to route the Cable Box's BEST DIGITAL audio directly to the Pioneer model number ????? (which would be helpful to know for this conversation).
Run the cable box's normal analog audio to the TV so you can watch it without the Pioneer turned on.
And route the best Cable Video (HDMI, Component?) directly to the TV. Unnecessary paths through the receiver can degrade the signal.
2/16/2011 11:56:45 AM • Pioneer 1000... • Answered on Feb 16, 2011
I have a pioneer amplifier that does not turn on.
A precise model and make might yield more-specific answer.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
1/14/2011 5:03:54 PM • Pioneer 1000... • Answered on Jan 14, 2011
How do i use the SPDIF input? it is on a pioneer
Any audio device that produces a digital output via spdif can feed the unit at that input.
For the future: speific model numbers are more helpful. We could refer to a specific manual.
If you don't have a manual, try retrevo.com
1/10/2011 3:14:41 AM • Pioneer 1000... • Answered on Jan 10, 2011
Where can I find a user manual for a Pioneer
The closest match which is available for download is Pioneer SX-316 S
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
10/23/2010 6:52:04 AM • Pioneer 1000... • Answered on Oct 23, 2010
I need to buy a
http://bestbuy.partsearch.com/Part/Pioneer+Electronics/Pioneer/AV7733P/Pioneer+Electronics/Pioneer/AXD7353/New.aspx
http://www.encompassparts.com/products/?AXD7353
http://www.dvdremotecontrols.com/Mfrs/Pioneer/PioneerAudio/AXD7353.htm
the last link i think is the cheapest....however bestbuy would be safest in my books :)
10/16/2010 7:38:51 PM • Pioneer 1000... • Answered on Oct 16, 2010
I am able to get
NEVER turn the volume up to MAX for testing. You'll destroy something when you finally find the switch that's wrong.
Can you provide a model number instead of a dubious power spec to describe the unit so we can know specifically what controls it has?
Has it ever worked?
Does the speaker adjustment routine (guessing it has one) make tone in all speakers?
What about the onboard FM? Is that too weak? If not, you need to figure out why external sources are too low.
I'd suspect a Tape Monitor is active when it shouldn't be. Or MUTE is on.
8/18/2010 10:25:07 PM • Pioneer 1000... • Answered on Aug 18, 2010
Sounds comes onbut for only a sec and goess off
Pioneer Model SDV77 Turns Of immediately Indicates DVD 5.1 CH Error DVD 3.3 Error
2/19/2010 3:42:45 AM • Pioneer 1000... • Answered on Feb 19, 2010
Cant install
y u cant.. just connect the speaker leads to the amplifier according to the indications including sub woofeer wire....
2/3/2009 1:31:18 PM • Pioneer 1000... • Answered on Feb 03, 2009
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
[email protected]
www.kanny-sounds.blogspot.com
1/27/2009 11:28:37 AM • Pioneer 1000... • Answered on Jan 27, 2009
I HAVE JVC SURROUND SOUND
Here is a link to the system cable that I think that you are reffering to. The model number of the system you have is TH-M45
The model number you gave is for the sub-woofer only. This is the system cable that is required to connected between the sub-woofer and the main head unit with the DVD changer in it.
http://www.jvcservice.com/store/ProductDetail.asp?Part=QAM0381-001%20%20%20%20
If you can not click on the above link, just copy the entire link and paste it into the address bar of your interent browser.
Since this is the part you want and it is the cheapest place to purchase it, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free technical support.
Thanks,
Dave
9/13/2008 1:45:37 AM • Pioneer 1000... • Answered on Sep 13, 2008
Pioneer DJM 600 Mixer: Disaster! Power Supply KO to Effect Board and Potentiometer Board
Replace the power supply.
4/12/2024 5:38:08 AM • Pioneer Audio... • Answered on Apr 12, 2024
The left channel on our Pioneer VSX-D409 is weak. Some sound is coming through, but very little. We have double checked the wire and the connection in back. Everything there is kosher. Any ideas?
Check the balance control. Apart from that the unit will have to be checked internally to ascertain where the signal is breaking down. This will require some skill and some equipment. My guess is it will be a dry solder joint or a dried out capacitor. If a capacitor looks 'leaky' or swollen, it is a good bet it is outside its tolerance and should be replaced. Sorry couldn't be any better help. Good luck.
2/23/2024 6:02:48 AM • Pioneer Audio... • Answered on Feb 23, 2024
Pioneer 1000 Watt 5.1 Surround Sound System System Logo
Popular Tags
23 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
find user manual pioneer
  • Audio Players & Recorders
