20 Most Recent
Pioneer PD-F907 CD Player Questions & Answers
CD's won't move...lights flash and CD's seem to be stuck in hold.
This usually means you have a CD stuck. I have had this player for over 10 years and have always just removed the case screws lifted the top off and removed the c\CD that is out of place (two in one slot for example) put it back together and it works fine. Hasn't really happened over 3 times. My kids got older!
Power
Check fuse and/or standby power circuit.
How to reset a pioneer vsx 456 receiver
To reset your Pioneer VSX-456 receiver, you can try the following steps:
Turn off the receiver.
Press and hold the "Enter" button and the "On/Standby" button simultaneously until "Reset" and "No" appears on your display.
Use the "Preset" arrow buttons to make the display say "Reset" and "Yes" .
Press the "Enter" button on the front panel to confirm .
If this does not work, you can also try unplugging all external devices before beginning the system reset. Switch the receiver into standby mode by holding down "Band" and then pressing and holding the "Standby/On" button for about two seconds. When you see "Reset?" on the display, press the "Preset" arrow buttons to make it say "Yes." Finally, press the "Enter" button on the front panel to confirm .
