20 Most Recent
Google Toolbar Questions & Answers
How do i make google chrome my home page
- In the top right corner of your computer's browser, click the Chrome menu .
- Click Settings.
- In the "Appearance" section, check the box next to Show home button. When the box is checked, you'll see a web address below it.
- Click Change.
- Click Open this page and enter your prefer website in the text box.
Click
OK.
if you want to make it go to your prefer website when you turn on chrome at
step 3. click the
ON START UP tick the box.
step 4. click the
SET PAGES then enter the prefer website.
Uninstall ask from chrome
Hi -- I'm assuming that your home page is ask.com. Simply go to settings (the three parallel lines in the top right corner). Then go to startup. Ftom there, you will be able to change the pages that load on startup. Hope this helps!
Internet explorer crashes
If Internet Explorer is crashing , your dilema likely lies with a buggy browser add-on. However, Internet Explorer crashes can have a alot of other causes, including incompatibilities with hardware rendering and possible malware.
crashes are often cause by buggy add ons. you can check to see if that is the problem by running internet explorer with out add ons
To do so, open the Start menu and launch the All Programs > Accessories > System Tools > Internet Explorer (No Add-Ons) shortcut.
If running Internet Explorer with no browser add-ons fixed your problem, you can disable the add-ons one by one to identify the one causing the problem. Click the gear menu and select Manage add-ons to open the Manage Add-ons window.
Select an add-on in the Toolbars and Extensions category and click the Disable button to disable it. Disable add-ons one by one - or disable them all and enable them one by one - until you identify the add-on causing the problem.
malware can often be a problem with applications crashing especially for an browser like IE. so scan your system with antivirus software for sure.
No access to google
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and HelpClick on the tools at the bottom of the drop down list will be internet options orClick start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browserbelow that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if dont need any of them you can disable or remove them
Deleting this toolbar
Google Toolbar? Open Control Panel, depending on your version of Windows, open Programs and Features, select Google Toolbar, Uninstall.
Screen on side
You can use the desktop toolbar on your computer to help you navigate around your computer, gaining access to programs and files. You may have previously moved the toolbar to the side of your desktop intentionally or accidentally. You can move the toolbar back to its original position at the bottom of the screen and lock it in place to prevent it from being accidentally moved in the future. Right-click on the toolbar at the side of your desktop with your mouse. Locate the "Lock the toolbar" option in the drop-down menu. If it has a tick next to it, this means it is secured in place. Left-click on the button with your mouse to unlock the toolbar. Left-click on the toolbar, and drag it to the bottom of the screen. Right-click on the toolbar, and select "Lock the toolbar" to fix the toolbar in place at the bottom of the screen. Hope this helps.
I can't find my Google bookmarks/toolbar
Hi tom_anneh Open a new tab, under the url textbox, your bookmarks should be there. OR click the wrench icon, then check the "Always show the bookmarks bar" Hope it helps.
How do I get Google toolbar back
Hi there! Just go to this page http://www.google.com/toolbar/ie/install.html it will ask you to download the toolbar just accept the terms and conditions.
Hope this helps!
Remove search history
If you are uding INternet Explorer left click on Tools (top left of home page).
A drop down menu appears with Delete Browsing History at top. Left click on this and your browsing history should be deleted.
However, you may still find some URLs in the Google search boxes.
Left click and drag over these one by one then hit delete on your keyboard to erase.
I am encountering the 0X80040206 error message
Ok well try this:
Close all your web browsers.
Uninstall Google Toolbar completely by going to Start -> Control Panel -> Uninstall a program.
Restart your computer.
Start your web browser and go to the Google Toolbar installation page.
As soon as the installation begins, close all your browsers while letting the installer to continue installing Google Toolbar.
This might solve your problem.
How do I erase bookmarks?
Go to "FAVORITES". Click on "ORGANIZE FAVORITES". Select the Bookmark(s) you want to delete and then click "DELETE".
If you want to delete your cookies, browing history, etc., go to "TOOLS" then "DELETE BROWSING HISTORY" then check the items you want to delete and click "DELETE".
Good Luck
I want Google to be my search engine when I click
Firefox didn't make it very easy to change your search provider, but you can do it. Here's how:
- In the address bar, enter "about:config" (not with the quotes).
- You'll see a warning screen; click on the "I'll be careful" button.
- Enter "keyword.URL" in the filter string box.
- Double-click the current value for keyword.URL, and in the box that opens, enter "http://www.google.com/search?&q=" and click OK.
This will make Google your default search provider. You can also click on the search provider icon at the left end of the search bar and pick Google from the drop-down list.
Thanks for using Fixya!
