20 Most Recent EliteGroup ECS G556 Notebook Questions & Answers
Max ram memory for chili green 556E notebook
probably 8gb if your computer is ddr3 but if it is ddr2 then max may only be 4gb
7/4/2014 3:09:23 PM • EliteGroup ECS... • Answered on Jul 04, 2014
Says no audio device wont play any sounds
Hi
you can get one from here
click on this link
www.realtek.com go up to downloads then choose the HD audio
download it
install it
then restart
hopefully this will give you the sound
good luck
2/27/2011 10:24:55 PM • EliteGroup ECS... • Answered on Feb 27, 2011
How to put a sound device?
first download the driver then double click the exe file
8/11/2010 7:58:06 AM • EliteGroup ECS... • Answered on Aug 11, 2010
After running for 5 minutes the machine sends 8
it send a deep and shut down indicating power failuer, check your power connection well.if the they are good the u would need an in lad physcal analysis by an expect to identify exatly what is wrong good luck
12/5/2009 12:36:27 PM • EliteGroup ECS... • Answered on Dec 05, 2009
My ecs g556 cant connect to the wifi router
Make sure you enabled wireless in your laptop and go to network list just refresh it will show you the available connection you applying the proper security code when it ask you.
9/17/2009 9:14:52 AM • EliteGroup ECS... • Answered on Sep 17, 2009
2answers
ECS GREEN556E Laptop Memory
the manual is here
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2258&areaid=2&LanID=0
pages 87 & 88 show how to install
it uses' ddr1 memory up to 2gb max total in the laptop
Memory
0MB on board, 2 SO-DIMM slots, up to 2GB
Support DDR 266/333MHz system memory
5/17/2009 12:56:54 PM • EliteGroup ECS... • Answered on May 17, 2009
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
I cannot find my administration key that is needed at the end of my installation of my motherboard. I cannot find the code in the box. Where is it?
Hi, Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
1/31/2015 8:52:47 AM • EliteGroup... • Answered on Jan 31, 2015
0answers
EliteGroup ECS G556 Notebook Logo
Popular Tags
9 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
after running 5 minutes machine sends 8
  • Computers & Internet
