20 Most Recent Microsoft Access 2002 for PC Questions & Answers
I m working in tours
Use data filter option in Excel to get data filtered as per your requirement & copy and paste into you access database
10/21/2017 4:11:01 PM • Microsoft Access... • Answered on Oct 21, 2017
Trouble inserting a different picture for each record. Want to link to file on another drive, and want the pictures to show up in a report.
A bound object is an object displayed within a field of a record in a table. Access can display the object in a form or print it on a report. A Bound object is bound to an OLE object data type field in a table. If you use a bound object in a form, you can add and edit pictures record by record.
An Unbound object is not stored in a table, it is placed on the form or report. An Unbound object control is the equivalent of a label control. To display the object for each record, you must place that field in the Details section of the form or report. Does this help?
6/1/2009 10:28:20 PM • Microsoft Access... • Answered on Jun 01, 2009
Hello to i need defination
A database is a collection of information (or data) that is organized to make retrieving specific information easy. Access isa software application used to create and manage a computerized database.
Microsoft Access is database software that tracks information for business or individuals. It's included in the Microsoft Office suite or as a stand alone program. Access is a relational database management system that links tables through common fields such as a part number, invoice number, or social security number. Relational database management systems can eliminate duplication of data and enhance validity by specifying relationships between tables.
3/24/2009 11:41:08 PM • Microsoft Access... • Answered on Mar 24, 2009
How to print only selected fields in ms access.
open your table in query, follow steps to do this...
1. open new query in access
2. locate the table
3. once table selected, select field name in selected table you only want to include in query
3. once finished selecting the field save the query
4. you can now view selected field in your table and print as well
5. you can edit the query anytime if you want to add or remove field
6. query will not affect your table since this is only query.
hope this will help you....
12/16/2008 7:51:06 AM • Microsoft Access... • Answered on Dec 16, 2008
How to export table in ms access to excel
yes you can export your access data into excel, follow steps on how to export.
1. open your access database
2. open the table data you to export
3. under table data view click tools menu
4. select analyze
5. select ms excel
6. this will open your seleted access table in excel
12/16/2008 7:43:37 AM • Microsoft Access... • Answered on Dec 16, 2008
How to create a program using ms access?
you need to study the basics of database programming. take short courses for database programming.
12/4/2008 4:55:51 AM • Microsoft Access... • Answered on Dec 04, 2008
Selected fileds to print
Start by looking under FILE, PRINT AREA, SET PRINT AREA
10/21/2008 2:20:59 PM • Microsoft Access... • Answered on Oct 21, 2008
About microsoft access2002
MS Access is not working means it is not opening? if u r trying to open project with out SQL server then u can't opwn. u can open only database file.
10/21/2008 5:55:55 AM • Microsoft Access... • Answered on Oct 21, 2008
4answers
Damaged mdb 2010 file gives strange error message
First one apply short guide, second make use of http://www.mdb.openfiletool.com/ MDB Open File Tool · Launch the Microsoft Access application, but do not try to open the corrupted MDB file.· Go to "Tools" in the top menu bar, expand the "Database Utilities" submenu and select the "Compact and Repair Database" option if you are using Access 2002 or 2003. If you are using Access 2007 or 2010, you can find the "Compact and Repair Database" option by clicking the Microsoft Office button and going to the "Manage" menu.· Highlight the MDB file that you want to restore and click the "Compact" button.· Enter a name for a new database file, which will contain the restored data from the damaged MDB file.· Navigate to the location on your hard drive where you want to save the restored version of the file.· Click the "Save" button. Access will now compact and repair the MDB file and save a restored version in the location you selected.
4/15/2019 7:01:03 AM • Microsoft Access... • Answered on Apr 15, 2019
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
I WANT THE CONFIRMATION CODE FOR MICROSOFT OFFICE PROFESSIONAL 2007 7 CHARACTERS A,B,C,D,E,F,G
2/15/2024 4:15:17 PM • Microsoft... • Answered on Feb 15, 2024
3answers
Need information about robots as an introduction?
ROBOTS
One of the least discussed topics in hobby level robotics is software. You can almost always find a hardware description, schematic, drawing, and tons of help on the electro-mechanical side of your project. However, the software, which admittedly is one of the hard parts, eludes many people. In this article, I would like to demonstrate how to structure your software so your robot will function properly.
I would also like to point out a great technique for getting started. Many software engineers make heavy use of something called 'Pseudo Code'. This is a technique where you write your program in half programming language and half human language (English, Spanish, Driud, etc). Pseudo code is very useful for getting the layout of your program ready, to get basic algorithms worked out, and to be able to read your 'code' quickly. I will demonstrate this technique a little later.
As for programming languages, it doesn't matter which language you choose to use. I personally use the 'C' programming language the most. BASIC, Assembler, or FORTH are all fine choices. It turns out that the language is a small part of the structure of your program. The software has a job to do, and the key is to get it done! I am going to write this article in SBASIC, but the techniques are the same no matter which language you choose. SBASIC is available from Karl Lunts website at http://www.seanet.com/~karllunt/tips.htm.
GRAPHICS
Basic Graphic Design Principles Part 1 Lines and Shapes
by Kelly Paal
This is part one of a two part article.....click here to read part 2. As a graphic designer, you need to know the principles of graphic design in order to design at your best. Knowing what the design principles are will help you implement the best layouts and help you become aware of what you have done wrong in your past designs. This article details information regarding graphic design as it pertains to lines and shapes.
PC JOBS
Types of Computing Jobs
  • Data Entry - This is a job just about anyone can get. Basically, you take information from a piece of paper and use it to fill out a form on the computer. Many old hands who started out in this role are now heading up computer departments.
  • Secretarial/Administrative - This position involves some basic office skills. Not only must you understand the basics of using your computer and a few applications, but you'll probably also be expected to take dictation, answer phones, type letters, and keep things organized. In terms of computer skills, you should know how to use word processing, accounting, and spreadsheet programs at the very least. People in this role often move into other computing roles such as Managers, Meeting Organizers and Human Resources. Naturally you can move into mainstream computing areas, particularly QA and Testing.
  • Power User - Not so much a position as a status of being an extremely proficient user of (typically) Microsoft Office or similar tools. Advanced users of these tools become familiar with the basics of computer programming through starting with Excel macros or Access database programming. One can become very valuable to a small business by learning such skills, and even start to consult with other small businesses at rates typically starting around $50 an hour.
  • Customer Service/Telesales - These positions usually place a higher emphasis on phone skills than computer skills, but you should know at least the basics of how to use your computer.
  • Technical Support (Production Support) - Most companies consider technical support to be an entry-level computer job. You are expected to know the operating systems on which the product you'll support will run, and you'll also need to know the basics of any programs that product might interact with. The good news is that the company will teach you what you need to know about their products - you just need to learn everything else. Success in technical support requires good problem-solving skills and a great deal of attention to detail. Technical Support and Problem Management is a rapidly growing area. Users now rely heavily on Help Lines, International Support Centers and the like.
  • Software Quality Assurance (SQA) Engineer - You need to know as much as the best technical support personnel. You need to be a problem solver, a detective, and sometimes even a Customer Service representative. You'll also need some basic programming skills, since more and more companies are beginning to rely on automated testing. The best SQA engineers understand a little (or a lot) about every aspect of computers, from building them to using them to programming them.
  • Software Engineer (Developer or Programmer) - To get a job at a top software shop such as Microsoft or Google, you'll need a degree in computer science and detailed understanding of the field. However getting a developer position in some small company may be easier. What do you need to know is the language in which you'll be programming. It is also important to know database fundamentals and (if programming for Windows) the Windows API. Knowing more than one programming language is very helpful. Understanding many of the basic fundamentals of computer science (e.g. linked lists, arrays, pointers, object oriented programming) will be essential in demonstrating your proficiency.
  • Business Analyst (Analyst or Systems Analyst or Analyst/Programmer or User Analyst) - This is a relatively new title, but the role is as "old as the hills". People can become a BA with any mix of business and computing skills. It is really a matter of looking at what the company is really after. A good BA should know the process from end to end. The BA is primarily the connection between the business and the developers. To get into this job, and into computing, good knowledge of a business is helpful. So, if you gain good knowledge through your job, and maybe do a computer course, you can get your foot in the door.
1/23/2024 8:20:10 AM • Microsoft... • Answered on Jan 23, 2024
2answers
Please i want source code calculator using asp.net
i want the source code for simple calculater in asp.net
1/8/2024 10:28:36 AM • Microsoft... • Answered on Jan 08, 2024
Is Microsoft Office Online similar to Google Docs?
NO, They are diffrent
12/26/2023 7:28:23 AM • Microsoft... • Answered on Dec 26, 2023
3answers
What is product key? nd
Please sent me for spb mobile shell softwares resistration keys
11/5/2023 6:35:23 AM • Microsoft... • Answered on Nov 05, 2023
2answers
Signature keyboard stopped working on Microsoft Surface pro x
simplest way to troubleshoot is to try another keyboard to determine whether your ports are in good order. Alternatively, try the signature keyboard on another device to determine if its working
8/31/2023 3:34:34 AM • Microsoft... • Answered on Aug 31, 2023
Microsoft Access 2002 for PC Logo
16 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Access Microsoft
  • Access Microsoft
Most Popular Question
about microsoft access2002
  • Computers & Internet
