20 Most Recent EliteGroup BKi810 Motherboard Questions & Answers
you can use the drivers from here
EliteGroup... | Answered on May 13, 2010
"Some days a diamond, some days a stone." If you must keep the old mobo, you might have to trade off for smaller partitions of that big 160.
EliteGroup... | Answered on Jan 28, 2010
You can download the drivers from :-
http://www.updrivers.com/drivers/Motherboard/Amptron/BKi810-Linux_Windows_2000_NT4_ME_98_95/12963.html
http://pcchipsusa.com/support-driver.asp
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
EliteGroup... | Answered on Sep 08, 2009
If that is an EliteGroup BKi810, you need PC100 or PC133 SDRAM. Any of these should work: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010170147%201052107967&name=168-Pin%20SDRAM
LED light on motherboard is indication your getting electric , Fan spins also is good indicator but it also does not mean the motherboard works though . If you tested CPU on second motherboard that should have told you the first motherboard has died . ( As long as the CPU can run on both motherboards that is )
EliteGroup... | Answered on Aug 13, 2008
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
EliteGroup... | Answered on Jul 25, 2008
check to see that if ur USB has infected with virus or scan your pc. let me know
EliteGroup... | Answered on May 04, 2008
The ECS website.
EliteGroup... | Answered on Oct 19, 2018
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
EliteGroup... | Answered on May 11, 2016
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
EliteGroup... | Answered on Feb 14, 2016
The manufacturer's support page for this motherboard can be found at the following link
http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0
Perhaps the answer to the question you have not asked is found there.
EliteGroup... | Answered on Sep 08, 2015
A manual for this motherboard can be found at the following link
http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip
In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours
http://www.ecs.com.tw/extra/productinfo/MB.htm
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
EliteGroup... | Answered on Aug 15, 2015
Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
EliteGroup... | Answered on Jan 31, 2015
EliteGroup BKi810 Motherboard Logo
7 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
need ram ram support
  • Computers & Internet
