20 Most Recent
EliteGroup (L7VMM) Motherboard Questions & Answers
L7vmm3 motherboard sound driver
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Hi goodday can you help
Sorry to say u can't do anything NOW!
The missing micro parts are lost forever!
Either u could bring it to the manufacturer to put new micro parts and spent a fortune!
The only way you could do is, install a SOUND CARD in the PCI slot!
That will solve your problem!
Taah!
Memory upgrade problem ECS mobo L7vmm3 rev 10
Hi
I have checked your motherboard specs, the reason it is failing is your motherboard is not designed to run PC2700 memory which is the DDR333 type memory.
Your motherboard is designed to take either
DDR 266 PC2100
DDR 200 PC1600
I would personally advise that you swap your 2 current memory modules out with 2 of the ones above and retry
I hope this has been useful
I have turn bios setting at :no in plug and play
Hi:
I am guessing that you have some other setting that isn't correct. Remove the CMOS battery, or move the CMOS jumper to the clear position. Hopefully the computer will boot. You can select the default settings to start with, and carefully move settings to what you want. Keep track of what you change, and if you change something and it won't boot, then that is what is hanging up your system.
Driver fr msi micro-star ms- 7255
buenas noches, la siguiente es para solicitarles el pack de drivers de la tarjeta madre msi ms-7255
la cual necesito, de antemano,,,,,,gracias!!
RE: Won't even start
ouch that hurts well i wish you well hopefully u get a new board and get the computer up soon best regards mike
Won't even start.. 0.o!
there maybe something wrong with your memory...
try removing your RAM and turn your pc on. If you hear a beep then there maybe hope in your pc. re-install the RAM and try switching your pc.
or
If you have an extra Power Supply unit, try replacing it.
hope this post helps :)
Loat install cd
u can download all the drivers from the website
www.driverguide.com. most of the drivers there u just register it and activate u can download all the drivers as you can
