20 Most Recent EliteGroup K7SOM (K7SOM W/CPU) Motherboard Questions & Answers
2answers
HOW I CAN FIND
There are more than one version of this motherboard. The following link will take you to a listing of all the K7SOM+ versions (plus other older motherboards from EliteGroup).
http://www.ecs.com.tw/ECSWebSite/Product/ProductArchive.aspx?CategoryID=1&MenuID=24&LanID=0#Archives
1/13/2011 8:56:05 PM • EliteGroup K7SOM... • Answered on Jan 13, 2011
0answers
I want cpu model
the site below should be able to help with what cpu processor you can use
http://www.motherboard.cz/mb/ecs/K7SOM.htm
3/26/2010 10:23:03 AM • EliteGroup K7SOM... • Answered on Mar 26, 2010
What cpu can I upgrade to using my K7SOM+
Provided below is a list of all supported CPUs for you're motherboard from ECS; http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=316&MenuID=69&LanID=0
The highest CPU is:
AMD Athlon XP 2600+ (.13u) (256K,266,Socket 462)
Cheers'
Mike
1/30/2010 10:56:19 PM • EliteGroup K7SOM... • Answered on Jan 30, 2010
I have a elite group mainboard the usb dont work
The USB ports don't need separate drivers.
They are supported by the operating system, although if you go into the computer setup, you may find that you have inadvertently disables USB support.
The drivers from the ECS site may be found here:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=79&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
11/7/2009 6:02:02 PM • EliteGroup K7SOM... • Answered on Nov 07, 2009
Planning to upgrade my RAM(motherboard K7SOM +
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
10/22/2009 8:10:18 AM • EliteGroup K7SOM... • Answered on Oct 22, 2009
3answers
WHAT IS THE MAX RAM FOR K7SOM + V7.5C MOTHERBOARD?
Each memory slot can hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
10/20/2009 3:06:24 AM • EliteGroup K7SOM... • Answered on Oct 20, 2009
I try to connect external HDD hatachi 160 cannot
go to start and run. In the command box type
diskmgmt.msc
Click Ok
In the Managament Console you should see your disk. You may need to format
it, or assign it a drive letter.
OR
UPDATE YOUR WINDOWS XP TO XP3
9/25/2009 6:59:23 AM • EliteGroup K7SOM... • Answered on Sep 25, 2009
No Power to Motherboard...
Here are some steps.
Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
Check the cpu power switch if it is correctly attached to the motherboard.
10/27/2008 1:06:26 AM • EliteGroup K7SOM... • Answered on Oct 27, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
EliteGroup K7SOM (K7SOM W/CPU) Motherboard Logo
Popular Tags
15 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
need usb driver k7son sis 740
  • Computers & Internet
