20 Most Recent EliteGroup K7SOM Motherboard Questions & Answers
0answers
K7som
Be the first to answer 3/10/2014 4:12:39 AM • EliteGroup K7SOM... • Posted on Mar 10, 2014Be the first to answer
DOES K7SOM MOTHERBOARD UPGRADABLE?
Hello here is the homepage:http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=79#Download-2And the + versions:http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=K7SOM+I would say no because the cpu does not exist anymore.The only thing you can upgrade is the harddrive and the ram module.The mainboard uses SDram and DDR ram in there own seperate block.Sdram is hard to find and expensive.DDRram can still be bought. The specifications:PROCESSORS 462 pin Socket A supports the AMD K7 processors Full series of Athlon XP/Athlon/Duron processors CHIPSET SiS 740 & SiS 961/962 Chipset SiS 740 Host/Memory controller with high quality 3D graphic accelerator SiS 961/961B/962 MuTIOL Media I/O Integrated USB 2.0 host controller in SiS 962 LPC I/O -ITE8705F LAN: MAC integrated in SiS 961/961B/962 and PHY on board AC97 Audio Codec: Compliant with AC97 2.2 specification SYSTEM BIOS AMI 2MB Flash EEPROM Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI Support for ACPI revision 1.0 specification MEMORY 2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously) Two 184-pin 2.5V DDR SDRAM (DDR266/200) or Two 168-pin 3.3V SDRAM (PC133/PC100) Maximum: 2GB (DDR SDRAM or SDRAM) I/O INTERFACE Hope this was helpfull
11/29/2012 12:10:22 PM • EliteGroup K7SOM... • Answered on Nov 29, 2012
2answers
Can u upgrade the processorto
On this motherboard you can use:
AMD Athlon (Highest being the Athlon 1400C running at 1.4GHz)
AMD Duron (Highest being the Duron 1800 running at 1.8GHz)
AMD Athlon XP (Highest being the Athlon XP 3200+ running at 2.3GHz)
AMD Athlon MP (Highest being the Athlon MP 2800+ running at 2.1GHz)
AMD Sempron (Highest being the Sempron 3300+ running at 2.2GHz)
2/25/2011 10:36:58 PM • EliteGroup K7SOM... • Answered on Feb 25, 2011
K7SOM has a series of beeps that are steady..No
If it is a long steady beeps , then it could be a problem with the memory.
try reseating the memory,try swapping the memory slots.try to boot the system with individual memory by doing this we will come to know whether the memory slot or the memory itself is gone faulty or not.
most of the cases reseating the memory will fix the issue.
1/3/2011 10:04:10 PM • EliteGroup K7SOM... • Answered on Jan 03, 2011
Como conectar panel 1 de esta placa?
See the image for the SW1 connector's description.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
9/26/2010 9:43:07 PM • EliteGroup K7SOM... • Answered on Sep 26, 2010
2answers
K7S0M+ Manual
6/1/2010 4:22:00 PM • EliteGroup K7SOM... • Answered on Jun 01, 2010
My computer has no displayed on the monitor but has a power..
Hello Wongcarlkley, hi, looks like you have memory module problem, need to clean module contacts using pencil eraser, try this fix first and see if it will solve your problem.
5/7/2010 2:43:27 AM • EliteGroup K7SOM... • Answered on May 07, 2010
I need the rightorder to put my new case wires ie
Hello james, this is the link for the motherboard manual, you will find here what you are looking for. http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=79&CategoryID=1&DetailName=Manual&MenuID=1&LanID=9
5/5/2010 7:09:37 AM • EliteGroup K7SOM... • Answered on May 05, 2010
I whant to know the cable order for the pins on
CHECK ON THE INTERNET SOME MOTHER BOARDS ARE LISTED WITH PIN OUTS.
3/10/2010 9:42:54 PM • EliteGroup K7SOM... • Answered on Mar 10, 2010
Need several drivers for this
Hi
I don't know about those versions like audio driver 2? They don't have such a version. But, you can find the latest drivers available for free HERE.
Good Luck
Mark
12/28/2009 10:55:02 PM • EliteGroup K7SOM... • Answered on Dec 28, 2009
Ive been reformated my computer,thees no sounds
Make sure you plug your speakers into the green port of the audio card. One port is aplified and one is non aplified. On some cards they have 5.1 output and usually the green is the front.
12/3/2009 12:48:17 AM • EliteGroup K7SOM... • Answered on Dec 03, 2009
2answers
Vga card
high resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
10/6/2009 2:57:54 PM • EliteGroup K7SOM... • Answered on Oct 06, 2009
2answers
Case front panel to motherboard wiring
Here is a link to the motherboard manual
And here is the hook up
6/3/2009 1:54:06 PM • EliteGroup K7SOM... • Answered on Jun 03, 2009
I have a K7SOM Motherboard and i lost my video & sound drivers
not wory windows(xp) will have the drivers in it bank
6/1/2009 10:20:56 AM • EliteGroup K7SOM... • Answered on Jun 01, 2009
Need the area on the motherboard
The SW1 Connector
This panel connector provides a set of switch and LED connectors found on
ATX case. Refer to the table below for information.
Device Pins
HD_LED_P 1
FP PWR/SLP 2, 4
HD_LED_N 3
RST_SW_N 5, 8
RST_SW_P 6, 7
KEY 9, 10
Pins 1-9 are closest to the edge of the board. Pins 2-10 are above 1-9. Number 10 is missing .
12/14/2008 5:31:39 AM • EliteGroup K7SOM... • Answered on Dec 14, 2008
Elitegroup k7som problems
check the memory card if the memory card is faulty the system would show no vga if u checked it the problem lies with ur mother board
12/5/2007 2:18:58 AM • EliteGroup K7SOM... • Answered on Dec 05, 2007
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
EliteGroup K7SOM Motherboard Logo
21 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
u upgrade processorto
  • Computers & Internet
