20 Most Recent
Microsoft Word for PC Questions & Answers
Ms word password break
Yes, that can be possible & of sure with the help of
this Office Password Tool, which can automatically find your forgotten password for protected Office
Word doc, Excel spreadsheet, PowerPoint and more. No matter the document is password
protected to be opened or editing, will help without any problems.
Best regards and good luck to you! - Seli.L
Microsoft Word, spacing in footnotes
Hello ablackwel208
By spacing, do you mean a blank lines between footnotes?
- In the document, Insert Footnote No 1 where you want it. You can use CTRL ALT F to do this and type the text of the footnote
- Scroll back to the document you need Footnote No 2 and repeat as before.
- Have a Print Preview to see the result.and exit from the PrintPreview
- Now you need a blank line between the Footnotes 1 & 2. To do this go to the VIEW menu and click on Footnotes. Goto the end of the first footnote and press the ENTER key to get a blank line
Hope this is what you want. If it helped you please give a rating.
Have a good day
luciana44
Issue Opening docx file
·Close Microsoft Word, then click
Start,
Run, type
winword /a and press Enter. Try to open the document using this copy of Word.
·Try to insert the damaged document into a new document. Create a new document, then click on
Insert,
File, select the damaged document and click
Insert.
·Try opening the file using WordPad then re-saving it to a new file, or copyimg the contents and pasting them into a new Word document.
Or try using a Microsoft Word document recovery tool such as Word Fix Toolbox
https://www.fixtoolbox.com/wordfix.html
How would I fix corrupted word doc?
You can attempt a repair by opening Word, File>Open Select the document and then where it says "Open", click on the little arro next to it and choose "Open and Repair". If this does not work then it is corrupted beyond repair.
Hope that helps, pls rate the solution
Damaged Word 2003 Document can't be opened
If it says that all you can do is to open it without formatting or graphic, that's all you'll get. Document is corrupt and you won't be able to open it Sorry if you needed to recover it. Just as a remote possibility, if document as made by you, look at recovery folderC:\Documents and Settings\"your login\Program Data\Microsoft\Word
My word file is corrupted by a virus
Lets get rid of th virus first. Run an online scan from here
http://housecall.trendmicro.com/uk/
Also download install and run malwarebytes from here
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
As to whether your files will be recoverable remains to be seen.
Revision Date Insert into MS Word
Since you would be "saving" a change to the document (being a revision), you may want to look into inserting a "Field" named "SaveDate" so it will hold the date the doc was saved.
Position your cursor where you'd like the date to be in your docuemnt, then: Insert > Field... > In Field names, select SaveDate, select a format and click <OK>.
Hope this helps!
I would like to break
Resetting password user name & password:
b>
*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Product key of ms word
Hello and thank you for your question,
You will need to contact Microsoft support to fix this problem. Please visit the following link.
Link: http://support.microsoft.com/kb/295539
Please remember to rate this answer for your ratings help me
better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all
your technological needs please continue to use fixya.com where you will find
the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Wiz: zdeuyo
