20 Most Recent EliteGroup K7S5A Pro Motherboard Questions & Answers
0answers
Pc won't boot
Can you get into the BIOS at all? Not sure what your motherboard is, but usually F1, ESC, DEL, or F10 get you to BIOS.Without a diagnostics card, or built in diagnostics like some gaming or server boards have, the beeps may tell you what is wrong if you go to the manufacturer web site and look in your product manual.If you can get to BIOS, some have a restore function to get you back to a different state, but even if that is not the case, you may be able to see something like a bad drive or memory chip being unrecognized that will identify the problem. If no to the BIOS or the BIOS was no help continue on:At each step, if the same beeps happen, reconnect the device and move to next and reboot. Power off completely between steps and unplug the PSU.1) Disconnect cd and hard drives, try to boot.2) Remove memory and try to boot.3) If motherboard has built in graphics, remove video card.4) Lastly, remove everything one at a time till you get to the BIOS with no beeps. If nothing but your monitor is connected, and you still get the same beeps, the motherboard or CPU may be faulty.If removing one item, ie the CD drive, allowed the PC to boot, then try a different cable, or IDE/SATA port. If memory removal allowed boot, then try one at a time in your main memory slot until you identify the bad module and replace it. If the motherboard boots with no VGA card, then that is a likely culprit, but switch to a higher power PSU and see if that allows you to boot. (some cards like the 6790 give messages to say you don't have enough juice, while the 4870 just makes the motherboard beep because no video device is attached technically)Motherboards aren't the easiest to debug, but if you have patience, you will be able to eliminate all possibilities and identify the root cause of the problem.
10/8/2012 8:43:33 PM • EliteGroup K7S5A... • Answered on Oct 08, 2012
I want to setting power
On the motherboard should be marked what goes where. I do not suggest you doing this. Experts do this without manual because they know what they are doing, but I understood that you are a rookie. But if you decide to do this by yourself, here's how:
Go to this link and download manual:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?detailid=269&MenuID=0&LanID=9
5/23/2011 7:59:41 AM • EliteGroup K7S5A... • Answered on May 23, 2011
Constantly freezes and at boot
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
3/20/2011 3:59:50 PM • EliteGroup K7S5A... • Answered on Mar 20, 2011
3answers
My athalon xp2000 processor died.
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
3/6/2011 7:48:51 PM • EliteGroup K7S5A... • Answered on Mar 06, 2011
3answers
I was messing with my
try resetting the CMOS by removing the battery that is on the motherboard for about 1min.
3/4/2011 6:03:19 AM • EliteGroup K7S5A... • Answered on Mar 04, 2011
I have a 'Cannot boot
More than likely your Pc will not support Windows 7, Most all my research points to this.
2/24/2011 6:07:33 PM • EliteGroup K7S5A... • Answered on Feb 24, 2011
Sound driver?
i get all my drivers from the manufacturers website or from driverguide
1/31/2011 4:50:27 AM • EliteGroup K7S5A... • Answered on Jan 31, 2011
The USB port on my Elitegroup K7S5A Motherboard
It may be the operating system has not recognized all the ports, if you operating system is now ok, go to my
computer>properties>hardware>device manager, and look to bottom of the list to USB Controllers.
Right click on them, and Uninstall all controllers and restart pc and see if all the ports are recognized and installed
automatically.
Go back to the controllers after restart and ensure there are no'!' ? marks or no 'X' against any controllers.
Hope this helps,
1/14/2011 12:53:31 PM • EliteGroup K7S5A... • Answered on Jan 14, 2011
My K7S5a Pro Board is not working properly. To
Remove the RAM, if you didn't do it yet, boot up. If you don't hear a continuous beep, then the mother board is faulty.
11/19/2010 4:07:57 AM • EliteGroup K7S5A... • Answered on Nov 19, 2010
I have a EliteGroup K7S5A
Have you upgraded to the newest Adobe Flash Player, and JAVA?
1) http://get.adobe.com/flashplayer/
2) http://www.java.com/en/
Restart your computer after downloading, and installing, if you are not directed to.
11/10/2010 3:10:14 AM • EliteGroup K7S5A... • Answered on Nov 10, 2010
I have an elitegroup k7s5a
with the error of video card, you can hear the warning beep of mother board.usually one long two short. if you don't hear anything .check memory card or cpu is installed firmly.
10/28/2010 7:44:43 AM • EliteGroup K7S5A... • Answered on Oct 28, 2010
Does this motherboard automatically recognize
automatic to a point,, its only if the processor isnt recgonised you need to configure the clockspeeds, this can be done via the Jumper on the pain board or via the cmos if it boots..
10/13/2010 2:34:23 PM • EliteGroup K7S5A... • Answered on Oct 13, 2010
WIRING DIAGRAM
my pc have no turn on with vedios for monitor but ihave check my pocesser and it's ok ram all so ok why
9/23/2010 4:48:59 AM • EliteGroup K7S5A... • Answered on Sep 23, 2010
0answers
EliteGroup K7S5A Pro Motherboard Logo
Popular Tags
81 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
  • Computers & Internet
