20 Most Recent EliteGroup V7.5A (K7SOM+ V7.5A) Motherboard Questions & Answers
0answers
Manual pdf k7som
Hello the manual can be downloaded here:http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=316&DetailName=Feature&MenuID=24&LanID=9Click on the download link, and you need adobe reader to read the content.Other models can be selected here:http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=K7SOMIf i am wrong by the model.Good luck
1/25/2013 1:18:04 PM • EliteGroup V7.5A... • Answered on Jan 25, 2013
3answers
I have a problem with my m/b k7som+ 7.5c. When I
There are a few procedures you can possibly try before replacing components.
I HIGHLY recommend you unplug power while trying these steps
1) Unplug power and remove CMOS battery (usually a small silver circular battery) on motherboard for 1 minuted then reinstall battery and see if it boots up.
2) Re-seat all RAM memory chips. If it doesn't help, then try booting the system 1 memory chip at a time, to rule out a bad stick of RAM
3) If you have a separate video card (not onboard video) then try re-seating it
4) unplug both data and power cables to all internal components (hard drives, CD-Roms, Floppies, etc) and also internal cards and see if it boots. If it does then reconnect one device at a time til you find the culprit
That's pretty much all you can do without swapping out parts.
I hope this help and I wish you luck!!
Regards
3/7/2011 3:22:36 PM • EliteGroup V7.5A... • Answered on Mar 07, 2011
Por favor necesito los controladores de esta
install your sound and vga driver
download here
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
1/22/2011 4:28:03 PM • EliteGroup V7.5A... • Answered on Jan 22, 2011
Eu formatei o meu pc
Eu preciso de saber o n?mero exacto impresso no cart?o-matriz para ajud?-lo a encontrar estes excitadores. Desculpe portugese mau, ele n?o ? minha l?ngua nativa
12/30/2010 1:52:36 PM • EliteGroup V7.5A... • Answered on Dec 30, 2010
Hallo ich suche ein Handbuch für EliteGroup
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
aaa6
10/10/2009 7:08:46 PM • EliteGroup V7.5A... • Answered on Oct 10, 2009
Need ECS K7SOM+ v7.5c mobo drivers
Try their US website here. It worked for me.
5/18/2009 9:24:17 PM • EliteGroup V7.5A... • Answered on May 18, 2009
2answers
Mouse freezes after installation of new graphics card
first update the bios of your system.
Then remove the drivers using safe mode, Download new drivers from nvidai web site ( do not use the drivers on the vga's cd). Disable any antivirus software and try again.
1/15/2009 6:55:25 PM • EliteGroup V7.5A... • Answered on Jan 15, 2009
Motherboard K&SOM+ V7.5A ELITE GROUP
Since you tried setting up the mic through windows & that failed & you are sure the drive software is also installed correctly, than the onboard sound chip is defective & that can not be replaced.
One other place you can also check is within Device Manager. To get to device manager, right click once on my computer & slide down to & left click properties. Click the Hardware tab than click the device manager button. Scroll down to & click the + plus sign next to Sound, video and game controller. Do you see a yellow ! point anywhere? If yes your sound driver software needs to be reinstalled. If no than I'm back to you're sound chip is bad. The only way around it ( if you're board is out of warranty) is to buy a PCI sound card. Just so you understand, this is very common with all boards that have a built in sound chips. You're sound (from you're speakers), may still function. Again this is normal, but the mic function can also be bad.
I'll list a link for a replacement PCI sound card below.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=107
There are some high tech cards here but you do not need a high tech card for Skype. Look towards the left upper side of the page & pick a card that will complement you're speakers. Ex: from 4.1 to 7.1 surround sound.
Good Luck!
If I can be of more service, just ask.
Mike
8/8/2008 11:27:32 PM • EliteGroup V7.5A... • Answered on Aug 08, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
EliteGroup V7.5A (K7SOM+ V7.5A) Motherboard Logo
18 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
need ecs k7som v7 5c mobo drivers
  • Computers & Internet
